The Reviews show the 790I Mobo does not like CAS 7, and advises CAS 8.
you just can't stop helping! thanks!
So do I just change the 7-7-7-20 to 8-7-7-20?
thanks.
thanks.
I'm running an S2E with 2GB OCZ Platinum 1333Mhz DDR3 7-7-7-20 and have no problems whatsoever. Have you run memtest yet?
I'd ask the place you bought it from for a upgrade to a EVGA 790i
the board's fine, its just the memory! all the 790i's are pretty much the same, apart from Asus' shoddy tech support!
Get rid of the Striker II board, its a POS, like all of the Nfail intel range of boards.
