I bought my wife a Bambu A1 Mini with AMS, We're not sure what setting were missing when printing, every print seems to be stringy at points and the final layer has this a lot...
If it’s PETG - PETG likes to absorb moisture naturally, and when you feed this moist filament through your printer and it reaches 200°, that moister instantly boils and leads to pops and strings like in your photo.
PLA absorbs moisture at a much slower rate, so usually you don’t have to dry it, but it can still happen.
A £30 Sunlu dryer from Amazon will do the job for PETG and PLA, put your filament in it overnight and then use the little hole on the front to feed the filament through and print directly from the printer
