Suddenly, my PC sounds like a jet engine and won't boot.
1 Dec 2010
Winchester, UK
For no reason (as far as I can tell) whenever I now try and boot my PC on the modded 6950 bios it makes a noise like Catrina has come back for more and refuses to boot despite being powered on. I change it back to standard bios (with the switch) and it seems to be working fine.
I didn't have this problem over the past month of using the bios just fine- if that is in fact the cause- what could the problem be?
Switch the bios switch on the 6950 to set back to default and see if it boots then.
