- 10 Sep 2006
Hi there, I just got the Scythe infinity the other day its got my 4000+ SD running at 3180mhz prime stable.
Thing is its not really doing that good as my old akasa 862 (they cost about £8) had it at 3120mhz anyway.
I realise why though, for some reason after it need about .5 of a volt just for the extra 60mhz...don't think the fan can quite cope with it (Its only a 1200rpm 120mm fan)
I was wondering what a good expensive high cfm (with as low a noise as possible) would be?
I'm not after something stupid like a Delta\Tornado (My days of tolerating a 92mm vantec tornado are well gone, as well as my hearing
Thanks...
So kinda after a 120mm fan with a very high cfm to noise ratio (can cost up to about £20)
Thanx
)Thanks...
Thanx
