Hi peeps,
I'm at work and have a graphics card out of one of our PCs which has failed due to a dead cooling fan. The card appears to be a Gainward Ti4200 64MB Power Pack AGP.
We need to replace the card with something of equivalent spec but I'm really not up to speed with modern graphics cards! I'm wondering what would be a suitable replacement? I assume the card we have here is a few years old now so the modern budget gfx cards would be sufficient? The PC runs a lot of graphical processes so the card needs to have a bit of ooomph, but shouldn't be too expensive. There are 3 of these PCs in total so we need to try and keep the specs as similar as possible, so the new card would ideally be able to use the same driver as the old one.
What do you suggest?
Thanks,
Andy
Thanks,
Andy
