SUMMER HEAT DEALS! LETS MAKE IT COOLER!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
See the below CPU Cooler deals, ideal as the heat is on with the weather being so nice.
Thermalright Venomous X Silent CPU Cooler (Socket 775/1156/1155/1366/AM2) @ £47.99 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs. pressure system for Intel CPU user only), and have a more efficient and secure mounting. Include AMD Socket AM2/AM3 Bracket system. Mirrored copper base increasingly upgrade the quality and the performance of the heatsink. Special bent winglet design, allows hot air to pass the heatsink more rapidly. Heatsink are all nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including FDB 600RPM ultra low noise Fan Cover set x2 and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
Heatsink Dimension
- Size: Length 127mm x Width 63mm x Height 160mm
- Weight: 755 g (excluding fan and bracket system)
- Heatpipe: 6mm sintered heatpipe *6 units
- Copper base: C1100 pure nickel plated copper base, with ultra-shine mirrored surface.
Fan Spec
- Dimension : 120 x 120 x 25mm
- Bearing Type : FDB (Fluid Dynamic Bearing)
- Rated Voltage : 12.0 VDC
- Operating Voltage Range: 10.8~13.2 VDC
- Rated Current: 0.130 Amp +10% MAX /0.11AMP
- Rated Power: 1.56 watt
- Rated Speed: 600 RPM ± 10%
- Airflow: 30.5 CFM
- Noise Level: 13.1 dB/A
- Life Expectancy: 60000 HOURS AT 40°c / 65%
- Net weight: 156 GRAMS
- Connector: 3 pin
Was £52.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
Thermalright Venomous X Black Edition CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366/AM2/AM3) @ £45.98 inc VAT
All new patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775 only). Mirrored copper base increasingly upgrade the quality and the performance of the heatsink. Special bent winglet design, allows hot air to pass the heatsink more rapidly. Heatsink are all Black nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including 2 sets of 120*25mm fan clips & 140*25mm fan clips and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
- Compatible with Socket 1366/1156/1155/775 & AM2/AM3
- Heatpipe: 6mm sintered heatpipe x 6 units
Was £50.99 Inc. VAT
Only £45.98 inc VAT.
ORDER NOW
Thermalright Silver Arrow CPU Cooler (Socket LGA1366/LGA1155/LGA1156/LGA775/AM2/AM3) @ £50.99 inc VAT
4 X 8mm sintered heat-pipes effectively take away excessive heat from the CPU when overclocked, Nickel Plated heat-pipes, slower Oxidation and deterioration of the heat-pipes, provide longer period of Thermal conductivity. Double fin design , each side with 147*103mm heat dissipation area, can be used with 12 or 14 cm fan ( fan clips included). Special Arrow fin design, which allows cool air to pass through and take heat away rapidly, effectively provide cooling for the cpu. Support Multiple-Platforms. Can be used on Socket 1366/1156/775 Platform, and AM2/AM3 Socket. Including two 160*140 Ultra low noise PWN fan. With the compatibility of up to 3 fans at a time.
- Cooler Dimension: Length 147mm x Width 123mm x Height 160mm
- Cooler weight: 825 g (excluding BTK and Fan)
- Heat-pipe: 8mm Sintered Heat-pipe*4 units
- Cooler Base Material: C1100 Pure Copper with Nickel Plating.
- Fan Dimension: Length 160mm x Width 26.5mm x Height 140mm
- Fan Speed: 900~1300 RPM (PWM)
- Fan noise level: 19dBA
- Fan Airflow: 69CFM
Was £56.99 Inc. VAT
Only £50.99 inc VAT.
ORDER NOW
Thermalright MUX-120 Black CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366) @ £39.98 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775). Heatsink are all Black nickel plated to ensure the best quality and performance and could last for years. Four sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Include Thermalright X-Silent series 120mm PWM Fan (600~1300RPM) Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
- Dimension: L133 x W58 x H160 mm
- Weight: Weight: 590g without fan ; 670g fan included
- Fan Rated Speed: 600~1300RPM
- Noise Level: 17~25 dBA
- Air Flow: 26.6~57.6 CFM
Was £44.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Thermalright HR-02 Passive CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366) @ £46.99 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775). Fanless design for low-noise operation. Proprietary through holes on fins for efficient ventilation. Heatsink are all nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including 120*25mm fan clips & 140*25mm fan clips and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
- Compatible with Socket 1366/1156/775 Socket AM2/AM2 (optional - if you buy the mountking kit)
- Size: Length 110mm x Width 140mm x Height 160mm
- Weight: 860 g (excluding fan and bracket system)
- Heatpipe: 6mm sintered heatpipe 6 units
Was £52.99 Inc. VAT
Only £46.99 inc VAT.
ORDER NOW
Your wish is my command :)
Thermalright Archon CPU Cooler (Socket LGA775/LGA1155/LGA1156/AM2/AM3) @ £48.98 inc VAT
Armor style heatsink fin array, with mirrored copper base, elevates heatsinks overall quality. Large heatsink fin array provides dissipating area of up to 150*125mm, making complete use of the airflow, with 140mm or 120mm fan. With the max width of 55mm, tall memory heat spreaders are avoided. Six sintered heatpipe design, all heatpipes are nickel plated, to slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the CPU. Supports Multiple-Platforms, and can be used on Socket 1366/1156/775 Platform, and AM2/AM3 Socket. For Intel sockets pressure is adjustable (40~70 lbs.) Includes one Thermalright TY-140 PWM fan, Ultra low noise at 21 dBA at max rpm (50cm testing distance). Fan-clips are compatible with both 140mm and 120mm fan. The Archon package includes a tube of CF III Thermal paste, to provide the best combination for use with Archon.
Heatsink Specifications:
- Dimension: Length 155mm x Width 53mm x Height 170mm
- Weight: 806g (excluding fan and mounting brackets)
- Heatpipe: 6mm heatpipe*6 units
- Copper Base: C1100 Pure copper nickel plated with mirror shine
Fan Specification:
- Dimension: L160mm x H140mm x W26.5mm
- Weight: 140g
- Fan speed: 900~1300RPM (PWM controlled)
- Fan noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Fan connector)
Was £52.99 Inc. VAT
Only £48.98 inc VAT.
ORDER NOW
Apart from the silver arrow which will obviously be better, how do these stack up to the TRUE120?
I want to upgrade the cooler but don't want to find I'm no better off lol
Had to be done, my best mate still is still using his stock cooler so he can have my Venom.
Chucked in a FC5 for good measure :D.
crickey, 4.4GHz on i7 950 (with Hyper Threading enabled) was easy to overclocked, at just 1.440 vcore and temperature still below 73C! My i7 920 @ 4.4GHz at 1.41vcore at around 88C (with HT disabled) with HT enabled is over 90C with Noctua D14
Don't take those results at face value, if u read their testing methods, all tests where on an open bench, so therefor not inside a closed case. And the Fan on both the true and Venomous was a 120cfm Delta.
Trust me Bulldog your DH14 would easily beat the Venomous, especially with decent fans on it.
Saying that my back up cooler is the Venomous, still in its box, as im still on water, but will use it eventually lol.
Yeah fair enough, I do have a Delta 120cfm as this is the worse loud fan I ever experience, sound like an aircraft ready for take off on the runway!
Personally, I am happy with 4Ghz with i7 as it faster enough and kept my temperature cool below 67C with 1.184vcore as the viper fan on the D14 is only spin around 1280rpm. I don't need 4.2, 4.4 anyway.
Re The Archon - if your case has a side fan on the door you probably will need to remove it ... as it is a beast@just over 170mm ... great cooler if it fits though!!
These would be tempting, but CPU cooling isn't my issue, its my southbridge which is getting too hot, and my GPU's in the way which would prevent sticking a bigger heatsink on there.
Are there any options for me, or is it just a case of sticking with the overclock I have?
The right size fan and a few zip ties worked wonders for me . Just got to rig it up right. May not be the prettiest but will do the trick,
