Permabanned
- 4 Sep 2011
- Durham
Hey guys,
So I posted this in the case section as I thought it may be the Corsair 780t case io section causing zero to happen when I pressed the power button from a cold boot. Since then I found out it wont turn on from the mobo power button either but I swapped kettle leads and it worked...cut to now and the same problem is back.
I still get power to the USB ports but it wont boot up and I'm stumped what the problem could be. When it does turn on it runs fine so I'm guessing the PSU is OK and its the MOBO? My specs are
4770k/h100i
Gigabyte z87x-ud3h
Titan X
Seasonic snow silent 1050w PSU
4770k/h100i
Gigabyte z87x-ud3h
Titan X
