As title, i've been running two 8gb sticks of 3866 ram with an i7-8700 since October 2017, i recently swapped out my fans so needed to go back into the bios and do the fan training.
When i got into the bios i found the ram was at 2133mhz, not good.
I've not changed the build since it was put together. I've gone into the bios and un/set the xmp, i've tried numerous different speeds and nothing above 3200mhz will boot, anything else give me the "failed to boot several times, enter bios and fix it" message and the ram is back to 2133mhz.
I've tried single stick, both sticks, different slots, unplugged the drives, etc and nothing will work.
What have i done to it?
edit, brainfart, mobo is asrock z370 extreme4 P3.30 bios.
