Q3 2010 for the GTX395, ironic is the fact 6800 will be out.
Interesting to see if true that the GTX360 is slightly slower than a GTX295 and hence slower than a 5870.
The gtx380 will obvioulsly be faster but on those figures doubt it will beat a 5970.
The price is going to be the key.
At 384SP the 360GTX would have been competitive against the 5870 either very slightly slower or very slightly faster... but with 480SP it would be quite a bit faster.
More rubbish based off of the last round of fake figures "leaked" by trolls/fanboys...
I like the entry at the bottom for the "395", wishful thinking there! 2 full-fledged 380 cores eh. Reality check people!
A 320 Shader part being salvaged out of a 512shader core is blooming awful in terms of performance for size of core, the fact that if those specs are to be believed, they are willing to get a 256shader part and waste half a core says a lot about the expected yields.
You do not plan to make a 256shader part, out of a core twice the size, its business suicide, you ONLY do that if yields are so incredibly poor that you really have no choice. The 320 part is a bad enough sign, the 256 screams that availability on a 512/480 shader part will be woeful.
I actually think its possible, theres no point making a 395 out of something less than I dunno a 400+ SP part, with two cores with that amount of shaders you're looking at over 300W anyway. They won't be able to sell something like that in large numbers, frankly if at all. If you can't sell it, stability, noise etc go out the window. This is Nvidia, they'll happily make a couple hundred full 2x380gtx cards, get it to reviewers, claim the performance crown and never expect anyone to ever be able to buy one.
