Hi, im using a tuniq tower on my quad core and temps seem a bit high, from core temp at idle this is what im getting. Core #0 49c, core #1 47c, core #2 48c, core #3 44c. Im sure i havent set the AS5 as good as i could have as it was my first trime doing it and when i put it on i ended up having to lift the cooler off the cpu etc and stick it back on before i even set it.
Anyway my question is, how should i go about appling the as5? on the as5 instructions it only has instructions for duel core, is what they say even the best method of application? It says on there web site to just put a beed along the center of the chip then put on the heat sink, doest mention spreading it, should i spread it anyway?
Also what is this lapping i see people saying in another thread? i guess its just applying a lair to both the cpu @ heatsink, will this help my temps?
Edit: also what temps should my qx6700 have at idle with tuniq tower with core temp?
