Tesla Model 3
27 Mar 2013
So I'm picking one up next Sunday. It's s 69 plate, but they were still trying to sell a warranty. Am I correct in thinking it should still have another 2 of full warranty, and another 6 of batteries/driveline?
27 Dec 2005
Bristol
Oh and for those of you newly picking up, I'd definitely recommend Teslamate (bit more difficult to setup but free if self-hosted) or Teslafi (terrible UI and costs monthly).
27 Mar 2013
It’ll have another 2 years of warranty if it has less than 50k miles (or whichever comes first). Drivetrain warranty is 8 years/100k miles or 120k miles (depends on the model) from new.
https://www.tesla.com/en_GB/support/vehicle-warranty
That's what I thought. Cheers. How reliable in general do you guys find the model 3, its the performance one I'm going for, I've heard its faster than an m4 from a standing start:cry:. Do you guys get your brakes greased every year?
EVH
EVH
Don
11 Mar 2004
Wales
Long Range model + performance boost software update > Standard performance and ~£10k cheaper ;)
Things you won’t get:
  • Adaptive suspension
  • Track mode
Better range through.
9 Mar 2003
Also better brakes and (better IMO) alloys.
Oh and the boot spoiler if that’s your thing (personally not the biggest fan).
27 Mar 2013
  • Track mode
Naa:p. It's used anyway so the difference is much less. I'm sure track mode will get me to work quicker:D.
26 Nov 2007
I just accepted a quote for a hypervolt so it looks like we are all systems go for March.
Out of interest what was your quote? I got quoted £1744 and £1394 with grants deducted for an untethered one. Seemed a bit over the top to me. The wiring install is about 20 meters but nothing too complex.
9 Mar 2003
It was £840 for the basic 5m tethered cable version and it’s going on a detached garage.
Standard install on a hypervolt is £350 or so plus the cost of the charger, less the grant so mine is slightly more than that.
It’s not the cable length that is the thing that pushes up the price, it’s everything else that sits around it. How complex the route is, access, if PEN fault protection is needed, RCD requirements etc.
Although mines on an detached garage, it’s a fairly simple run with no access issues. My consumer unit is on an external wall, the cable will run externally around the outside of the house, under a couple of slabs (only sanded in), it pops into the side of the garage and pops back out the front behind the charger. I’m probably about 15-16 meters all in.
I think the hypervolt has built in PEN fault protection so it’s simple in the electrical side.
26 Nov 2007
Your quote is much nearer to what I would have expected to pay but it sounds like your house is an easier install, My consumer unit is in the middle of the house so requires a cable run into the attic and down an external wall but nothing to difficult as I had solar fitted a few months back who at the time made a nice easy run for the next guy to follow.
I think I'll probably just research the requirements and do it myself.
18 Oct 2002
Sussex
Echo this, I have Teslamate running on my diskstation and it gives tons of geeky information about your car and stats to look at when your not in it ;)
Here's a drive back from the o2 a few days ago :) Just under 20kwh at 5p so £1 for 75 miles, 4 people onboard with all the seat heaters running cruising at 70 on lane keeping for 80% of the journey.
teslamate by
9 Mar 2003
That run sounds more complex.
You can’t fit it yourself but I guess you could source the correct cable and run it where you want it and have a qualified person connect each end.
Any reason why you are going for untethered? Most suggest tethered cables.
18 Oct 2003
I went for Tesla Gen3 Wall Connector as even though it doesn't get the grant, quotes were still competitive. It did just go up £40 though..
26 Nov 2007
Yeah, I suppose then I could still claim the grant.
It's just what they quoted for but I'd opt for tethered if I went ahead.
9 Mar 2003
I like the look of the Hypervolt 2nd choice would be the Zappy. I believe both can make use of excess solar energy during the day.
I was looking at the Zappi as well but it didn’t pass the aesthetic test (aka Mrs Sk8) and to be honest I can’t say I disagree either. She was up for an Anderson until I told her how much extra it was.
I don’t have solar (yet) but the main requirement was a tethered charger that deals with the cable in a sensible way which tends to knock a few out just in that.
18 Oct 2002
West Midlands
Fit a weather proof box around one that you find less suitable, plenty of people have done it, and I would have done it with the Ohme but I can see it from any obvious angle so there was no need. The other bonus is you can buy a lockable one if you want, no so much that people can't use it but it won't be long before the thieves are out stealing them. :(
EVH
EVH
Don
11 Mar 2004
Wales
Zappi? Christ, it’s like a fisher price charger.
Build quality is gash at the moment too. lots of threads online about the RCDs burning out.
Easee Home charger ftw.
