Testing a DC motor?
22 Oct 2004
Berkland
Hi People,
Im trying to figure out why my force feeback steering wheel broke, so I have currently go it in bits.
I want to check to see if it is the motor that is used to generate the feedback, which I am sure is just a bog standard DC coil motor. So whats a good way of testing it to see if it is broke?
Cheers
Caporegime
19 Apr 2008
Essex
A 9V battery would usually suffice. The can of the motor should say what the rated voltage is so try not to go over that.
OP
22 Oct 2004
Berkland
Cheers Janesy
Okay, i managed to test it by hooking up a ohmmeter to the +ve and -ve and then checking its resistance, and it appears that its not shorting out, so I think the motor is fine.
So maybe it is the power brick that powers the controller. What ways could I test that? (without blowing myself up by pluging it in and then measuring the output plug)?
