** THE PHANTEKS DOMINATION CONTINUES - INTRODUCING THE PRO & PRO SE GLASS EDITIONS **
OcUK Staff
26 Nov 2014
Stoke
Phanteks are back with an updated version of one of their most popular cases - the Enthoo Pro. The Pro was the second case that Phanteks originally released, after the Primo, and Phanteks have revitalized the chassis with a tempered glass side panel, along with both a white interior and a pair of Halos RGB fan frames on the special edition. Other than that, the Pro hasn't been structureally changed, due to it's very impressive feature set, including support for up to SSI EEB sized motherboards, support for 360/420mm radiators on the top with 240mm radiators at the front and bottom along with comprehensive HDD/SSD support, up to 472mm VGA cards, 193mm coolers and 318mm PSU's. Basically, you can fit most things inside this beast and look good doing it. Stock is due mid January, preorder now as stock is strictly limited.
Phanteks Enthoo Pro Glass Midi Tower Case - Black @ £99.95 inc VAT
Black Midi-Tower design, Tempered glass side window, Extensive watercooling options, 2x 140 mm fans pre-installed, Superb cable management
Only £99.95 inc VAT.
ORDER NOW
Phanteks Enthoo Pro Glass Special Edition Midi Tower Case - Black/White @ £116.99 inc VAT
Black-white Full-Tower design, Tempered glass side window, Extensive watercooling options, 2x 120 mm and 1x 140 mm fan pre-installed, 2x Halos RGB fan frames, Superb cable management.
Only £116.99 inc VAT.
ORDER NOW
