ThermalTake Armor 250mm Side Panel
kao
kao
7 Oct 2006
Essex
Is there anywhere to buy the sidepanel with 250mm fan seperate? I already have the case but obviously don't want to buy the case again just to get the side door =p
Can't find just the panel for sale anywhere, and wondered if it was actually available or not.
Hopefully someone knows =)
i could do with one aswell. im going to modifiy one if i can find one but iv not found one yet.
my friend who has the esact same case as me tho the thermaltake armour, im going to buy his case and modifiy it when i get round to it. :)
Thing is there is really no need for a 250mm fan :s
The fans that thermaltake use for the 250mms are pointless, they are no quieter than a decent 120mm fan, and that particularly 120mm pushes enough air for what is needed!
I'll leave you to go buy pointless gimmicky products.... :confused:
they do shift air, you cant feel it with your hand tho. put a peice of paper over it and watch it fly :cool:
its pretty powerful really
Ok..
I have some near silent fans in my pc that are much smaller than a 250mm, and also much quieter (from what I have been informed these are not particularly quiet) and you can feel some air coming off of the as well as "watch a piece of paper fly"
I am yet to see valid justification in 250mm fans.
Hi,
I just bought a second hand kandalf and have been looking to source this panel. I have found the shipping from the states is too high (cheapest $60) but you can get these in Europe but not in the UK :( I have found one for £36 delivered from the continent. Will be ordereing it just after xmas if it arrives ok ill post back lol :D
cheers,
Hugest
Personally i want another solid side panel on mine and take that window one off, so i can get my own design cut into it, but i cant get the solid side panel anywhere, i could swap them around but then the TK pressed name will be upside down on the MB tray side, and will look stupid.
jaykay said:
only place i know that sell 25cm fans are american
I'm not looking to just buy a 25cm fan... I want the side panel for the Thermaltake Armor case which has a 25cm fan. You can buy the case with the 25cm fan side panel but when i bought the case the 25cm fan version wasn't out afaik =p
what i was thinking about doing if i got another thermaltake armour side panel which i allso cannot find anywhere, i was going to get a 50cm desk fan with 3 ajustable speeds, which you can feel the air flow from 20 foot away :D and was going to attach it to the side :D :D
it would look a bit........ odd? but still lol, would be a daft invention,
but iv decided to get water cooling next year instead, but still i need a side panel so i can just cut all the bits goin across off it, i hate them
Yeh i cut the bits going across the sidepanel, definately looks better now! :D
Hugest_UK said:
Hi,
cheers,
Hugest
you be better going and buying the full case from the first hit that comes up for the 250mm fan at 40 quid
Hi,
not when i got the case for £42 ;) That makes £78 total (£36 for the side panel with fan). :D You cant get a new one with panel anywhere near that price.
Cheers,
Hugest
i doubt that, as ive been searching for one these for ages.
ive asked ocuk to get these and they told me no
i tried all over the uk and nothing
only place is american sites, they do some nice blue modded ones aswell, but they are costly to ship to uk
Hi,
Holy thread resurection batman!!! If anyone still needs one of these I know a place doing them in the UK for about £15 :) Email in trust. I have one on my kandalf right now :D
Cheers,
Hugest
