Thornwick Bay Sunset
13 Jul 2004
Bridlington, East Yorkshire
Hey all,
Went to Thornwick Bay last night to capture the sunset, heres what i got:
Lovely, I like that.
Can't help but feel there's a touch too much foreground in the lower left. Not a lot you can do about it now - cropping would bring the horizon to the middle, ending up feeling a bit uncomfortable.
I also still maintain that a denser ND grad (or more?) really wouldn't go amiss. You've got a loverly sky here, but it is rather blown out above the sun - I just feel it could do with some more pop.
Water exposure is spot on :D
Can't get ND Grads to use on a 10-20mm lens, as you get too much vigertating, as the light can get behind the holder.
Lovely capture!
Have to echo whats been said about the grad filter though. It would give the picture that bit extra. Could try a bit of blending from a few exposures if you shot in RAW...
Also the Lee filter system works perfectly with my 10mm lens. Its pricey but worth every penny.
