Hi there
OK adding over 150+ BHP and even more torque along with more weight on the front-end means I get brake fade and real quick, plus the stopping power could be better. So its time to upgrade my braking system.
What do you guys think of the following kits and options:-
1. Saleen 14" Brake Kit
This kit includes 6 Piston Calipers, 14" 1-piece rotors which I am not sure if they are blank, grooved or drilled. Fast street pads, steel braided hoses and Motul RBF600 DOT4 brake fluid. This is factory kit that is installed as STD on all Saleen SC cars and is compatible with the ABS unit.
Price: $1599
2. Ford/Shelby/Brembo GT500 14" Brake Kit
This kit includes 4 Piston Calipers, 14" 1-piece blank rotor and pads. Again this is a factory kit so is proven compatible with the cars ABS.
Price: $1100
3. Baer Eradispeed Plus-TWO 14" Rotors Front & Rear
This kit HAS NO CALIPERS!!
The kit comprises of front 2-piece 14" drill/grooved rotors and also 14" rear drill/grooved rotors. They are 2-piece with an ALU HAT, basically makes them lighter, about 3kg per corner than the stock rotors I believe.
For pads its Hawk HPS which are very highly rated.
Price: $1450
So what do you guys reckon is best?
Not really to bothered about the prices but the Shelby is a nice kit but unfortunately there is a long waiting time. The Saleen kit looks really good with great stopping power and is in stock now. Plus this kit is normally $2000, Saleen are just giving me a good discount.
I like option 3 the Baer Eradispeed rotors because they reduce un-sprung mass but their again on a car with over 500BHP, I am sure 3kg per corner will not be noticable anyway. Plus they are not a factory fit item so are not as in much use and as such not much user feedback.
Price: $1599
Price: $1100
Price: $1450
