1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Titan Amanda TTC-NP04TZ TEC & Heatpipe Cooling Fan
Discussion in 'Overclocking & Cooling' started by ~The~King~, 13 Apr 2007.
  1. ~The~King~
  2. gt_junkie
    Sgarrista
    I'm getting one today so can confirm in the next day or so. But it is my understanding that the pci card is needed to power the TEC portion of the cooler.
    Without it installed i would imagine it would just act like a mid-range bog-standard air cooler. Possibly even worse as the TEC may actually be insulating it a little!
    Get it plugged in fully and report back. :)
    gt
  3. cobxx
    Gangster
    AFAIK, if it's like other TEC coolers, it will need the power, otherwise it is just acting as a normal heatsink. Someone who has one though should confirm that to make sure I'm not just making that up. :rolleyes:
  4. ~The~King~
    from what ive found out, is that it is essential to have the pci card installed as well..
    the only annoying thing is that i havent got a spare pci slot...
    only a pci-e
    does ne 1 know if either:
    1) where i can find a cheap pci-e to pci converter
    or
    2) if titan provide a pci-e card instead of the pci version?
  5. gt_junkie
    Sgarrista
    Don't think so on either of those points i'm afraid.
    What do you have filling the PCI ports you have already?
    Do you have pics?
    gt
  6. ~The~King~
    currently got 2 8800gtx cards
    also just found this:
  7. gt_junkie
    Sgarrista
    Ahhhhhhh! ;)
    You lucky king! :D
    Is there no final PCI slot at the very bottom of the mobo? Or do you have a soundcard there?
    gt
  8. ~The~King~
    well, ive got 1 sound card in one...
    and the other one is inacessable cos of one of my 8800's
  9. Ice Tea
    Mobster
    Looks like your be selling the Titan to me for £45 then :D :D :D
  10. gt_junkie
    Sgarrista
    If you can cope with on board sound then i'd dispense with the soundcard and get the cooler working.
    With two GTX's you're hardly going to be worrying about improving game fps' with a sound card. Either remove that or downgrade to a single GTX if you can to free up that second slot.
    What monitor do you have it on? You'd only need 2 GTX's with a 30inch tft monitor or high resolution CRT.
    Anything smaller would be wasted on 2 GTX's.
    gt
  11. gt_junkie
    Sgarrista
    Or that i suppose! ;) :p
    gt
  12. Ice Tea
    Mobster
    Wonder why Titan chose to use a PCI slot .
  13. gt_junkie
    Sgarrista
    Maybe they thought it was a nice tidy solution. Better than a coiled bundle of cabling connected to a control box and molex. Suppose it could have ended up looking like the kit you have to hide when installing cold cathodes!
    They didn't think about high end users who had every slot filled or obscured though! :rolleyes:
    gt
  14. Had3s
    Gangster
    The Ultra ChillTEC comes with a front control bay and doesn't need a PCI slot. I'm in the same predicament with my twin gfx and x-fi taking up the room. From the reviews, the ChillTEC humps the Amanda anyway. Gotta order from somewhere in the USA but isn't too expensive.
  15. Vengance
    Hitman
    On a funny note with this cooler, if your cpu drops below 10c your system will stop booting :p
  16. Ice Tea
    Mobster
    @~The~King~
    Did you get it sorted ?
