Titan Vanessa and The BEst Way to Fit the Fan
28 Oct 2005
Scotland
So........
My mate is using my old Titan Vanessa Cooler for his system and has bought two 120mm Xilence Red Wing fans with one to exhaust air out the back and the other to go on the Vanessa! Now the question I have here is what do you guys feel the best way is to put the fan on the Vanessa.
With the fan on the Vanessa so that it vents Air out the back also, meaning both fans would be fairly close but not touching, a kind of extreme tunnel in a way.
Pointing downwards towards the Graphics Card?
Upwards towards the Power supply intake fan to vent out the back?
Facing the front of the Case so that it takes air Across the Heatsink and then out the back of the case?
Just curious as to what would be the best here as I have searched and cant find an answer
You always need to vent the hot air as quickly as possible out of the case. So point it to an exhaust fan. You dont want to recirculate hot air in the case as it will just heat everything else up.
