**Today Only 01/04/2011** Fractal Design Define XL Full Tower Case & Gigabyte GeForce GTX 560Ti SUPE
22 Aug 2010
TODAY ONLY - SPECIAL OFFERS....
For the same price as the smaller case, and now reduced even further, for Today Only, get you hands on the Fractal Design Define XL Full Tower Case in Black Pearl, now just ££83.99
SAVE OVER £30!! Yes this deal is for real, get the worlds fastest GTX 560Ti for under £200. Gigabyte GeForce GTX 560Ti SUPER OC 1024MB GDDR5 PCI-Express Graphics Card, now just £199.98
Fractal Design Define XL Full Tower Case - Black Pearl @ £83.99 inc VAT
As the name implies, Define XL is the larger sibling of the acclaimed and award winning Define R2/R3 case. Similar to Define R2/R3, it offers a number of interesting functions with a very stylish appearance. It’s a case focused on low noise level, without neglecting other important features such as cooling, expandability and ease of use.
The XL is pre-fitted with dense noise absorbing bitumen material, covered with a soft foam texture. This material effectively absorbs noise generated by the components and fans inside. Paired with other noise preventing features such as a covered top panel with a 180mm fan mounted with an angle to blow out air in the rear and silicone grommets for hard drive mounting, the XL truly excels in delivering a low noise solution.
An important feature of the XL is the division into three thermal chamber designs. This enables the user to freely choose the best thermal configuration suited for their needs. First is the upper main chamber, containing most of the components, such as motherboard, ODD and one HDD cage. The main chamber is cooled by one 140mm fan in the front (included), one 120mm fan in the front (optional), one 140mm fan in the rear (included), one 120 or 140mm fan in the side panel (optional) and one 180mm fan in the top (included). The top 180mm fan is mounted with an angle, blowing out hot air through the rear side of the case. As mentioned earlier in the text, having the top covered has a clear acoustic advantage, in not letting noise emit from the top of the case. The main chamber is connected to the second thermal chamber, the PSU chamber, with a removable lid. The lid can be removed if the user wants to turn the PSU upside down, pulling out air from the main chamber. Standard, and recommended, configuration is though with the lid closed, letting the PSU taking in air from the bottom of the case, through the supplied filter.
The third chamber is the lower HDD chamber, consisting of room for six hard drives. This chamber is cooled by an optional 140mm fan in the front. The standard configuration is to let the air that has gone through the HDD’s and therefore is hot, go out behind the right side panel (seen from the front) and out in the rear of the case. However, the user can decide to remove the dividing metal panel between the lower HDD chamber and the PSU chamber, to let the air flow over the PSU and out in the rear ventilation holes.
Another unique feature with the XL is the ModuVent™ feature, inherited from the Define R2/R3 case. This is a cover fitted with noise absorbing material, mounted in the side panel fan hole, allowing the user to choose between an optimal low noise level, having the cover mounted or optimal airflow by removing the cover and mounting a fan for intake.
Apart from all these features, XL also offers excellent cable routing possibilities, with large holes and well enough space for cables behind the M/B plate. The cable routing holes are covered with silicone covers, effectively hiding the cable clutter.
A fan controller, which can be mounted in an expansion slot in the rear, is included. It can control up to three fans with one knob.
- 4x 5,25” bays, 1x 5,25” to 3,5” converter included
- mini-itx, micro ATX, ATX and E-ATX motherboards
- 10x HDD trays. 4x HDD trays in the HDD cage in the main chamber. This HDD cage is removable and rotatable. 6x HDD trays in the lower HDD chamber. These HDD cages are fixed.
- A total of two 140mm fans and one 180mm fan included. Front 140mm fans are mounted with removable, washable filter. A fan controller is included, for mounting in one of the rear expansion slots.
- Pre-fitted with dense noise absorbing material in both side panels.
- ModuVent™ feature, allowing the user to choose between an optimal low noise level, having the cover mounted or optimal airflow by removing the cover and mounting a fan for intake.
- 2x 140mm fans (one 140mm included, one optional) with removable and washable filters, in the front. Recommended for intake of air.
- 1x 120mm fan optional with removable and washable filter, in the front. Recommended for intake of air.
- 1x 180mm fan included in the top of the case. Recommended for exhaust of air
- 1x 140mm fan included in the rear of the case. Recommended for exhaust of air
- 1x 120/140mm fan optional in the side of the case. Recommended for intake of air
- Case size (WxHxD): 232x560x561.3mm
Only £83.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 560Ti SUPER OC 1024MB GDDR5 PCI-Express Graphics Card @ £199.98 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- GPU Gauntlet Sorting Technology
- Ultra Durable VGA+
- 7 phase PWM design (6 phase for GPU; 1 phase for memory)
- WINDGORCE 2X Cooling Design
- Voltage Read Point Design
- Core Clock: 950MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4580MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1900MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 3 years
Only £199.98 inc VAT.
ORDER NOW
