25 DAYS
Inno3D GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (N980-1DDN-M5DN) @ £419.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £419.99 inc VAT.
ORDER NOW
_____
Acer CB270HU 27" Widescreen LED Monitor - Black @ £289.99 inc VAT
This monitors provide stunning image quality and sharp details with UHD, WQHD and FHD high resolution.1 These monitors also have 6-axis color adjustment to meet the highest standard in color accuracy. With the clear view provided by these monitors, you can see work clearer and get jobs done quicker.
Wide viewing angles1 on the Prosumer Series preserve image clarity for better views all around. Their wide color gamut1 presents more colors on the screen. Flicker-less technology combined with a 1 ms response time removes screen flicker and renders images faster. What's more, Acer ComfyView technology reduces reflections to provide more comfort for your eyes.
These monitors are equipped with low dimming technology that automatically adjusts the screen and a multi-function ErgoStand that allows you to adjust the viewing angle for maximum comfort. You can seamlessly expand your view across multiple monitors thanks to a Zero Frame design1, or see more on the same screen with picture-in-picture1 and picture-by-picture1 technologies.
Prosumer Series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting. These monitors meet several international standards for green technology, including ENERGY STAR® 6.0 certification, EPEAT® Gold qualification, and Certification.
Specification:-
- Height adjust stand with pivot and swivel
- IPS Panel
- 178/178 Viewing Angles
- Viewable Image Size: 27" (16:9)
- Brightness (typical): 350 cd/m2
- Contrast Ratio: 100000000:1
- Response Time: 6ms
- Optimum Resolution: 2560 x 1440 @ 60Hz
- Colors Supported: 16.7 Million
- Inputs: RGB D-Sub, DVI-D, HDMI & DisplayPort
- Built-in Stereo Speakers: Yes / 6W
- ENERGY STAR ? Compliant: Yes
- EPEAT Rated: Yes
- Warranty: 3yr
Only £289.99 inc VAT.
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
_____
Specification:-
- IPS Panel
- EPEAT Rated: Yes
- Warranty: 3yr
ORDER NOW
