**Today Only 02/06/2011** Toshiba C660-10D 15.6" LED Laptop & Kingston HyperX Genesis Grey 4GB 1600M
22 Aug 2010
Today only, if you are looking some some great products with price drops you have found it! These great price will be going up at the end of the day!
Toshiba C660-10D 15.6" LED Intel Dual Core T4500, 4GB RAM, 500GB HDD, DVD-RW, Win7 Home Premium @ £335.99 inc VAT
If you’re looking for an everyday laptop to enjoy your media, produce documents and browse the internet on, the Toshiba C660-10D 15.6” laptop should fit the bill.
Thanks to its speedy 2.3GHz Intel Pentium Processor, 4GB of memory and spacious 500GB SATA hard drive, you’re capable of running multiple, and memory intensive, applications at the same time on your Toshiba C660-10D.
Browsing the web over a Wi-Fi network is a breeze, and depending on the connection strength, you’ll be able to quickly and reliably jump from different pages and sites. You’ll experience fast downloads and video streaming from sites such as YouTube and the BBC.
Furthermore, an integrated webcam lets you see the people you’re chatting to online without having to install any additional software. It’s great to use in conjunction with Skype or MSN Messenger.
The Toshiba C660-10D has a full-size keyboard, with integrated numeric keypad. A built-in multi-touch trackpad means you don’t need a mouse to move your cursor around the screen, or open and zoom into images. Of course, if you’d prefer to use a mouse, you can always connect it to one of the two USB ports.
When you’re not working at your computer you can sit back and enjoy films and video clips on the laptop’s 15.6” screen. The TruBrite screen delivers bright and vivid colours, so your multimedia content really comes to life. This is combined with impressive sound from integrated stereo speakers for an immersive movie experience. Films can be popped into the DVD player/rewriter, or you can play content directly off your hard drive. With Windows 7 Home Premium included, setting up and watching your multimedia content is simple. Furthermore, photos can be uploaded onto your hard drive from a mult imedia card - the Toshiba C660-10D laptop has a 2-in-1 card reader.
All of the content on your Toshiba C660-10D 15.6" laptop is well-protected, thanks to its face recognition password system. Instead of typing in a memorable word each time you want to log-in, the webcam scans your face to see if you’re allowed access to the computer.
What’s in the box:-
- Laptop
- AC Adaptor
- cable
- User manual
- Quick start guide
- Included Software:
- Toshiba Disc Creator
- Toshiba User's Manual
- Supervisor Password Utility
- Toshiba Assist
- Chicony Camera Assistant Software
- Toshiba Face Recognition
- Toshiba DVD Player
- Microsoft Office Home and Student 2007 (free 60-day trial)
- Toshiba Value Added Package (Toshiba Power Saver, Toshiba Zooming Utility, Toshiba PC Diagnostic Tool, Toshiba Flash Cards, Toshiba Components Common Driver, Toshiba Accessibility, Toshiba Button Support)
- McAfee® Internet Security (includes free Internet updates for 30 days)
- WildTangent Games Console
- Toshiba Photo Service
- Toshiba Recovery Media Creator
- Google Pack (Google Toolbar, iGoogle, Google Picasa)
- Connectivity Doctor
- ConfigFree
- Toshiba utilities and drivers
Specification:-
- Screen Size: 15.6" (TruBrite)
- Processor Type: Intel Pentium Dual Core T4500
- Processor Speed: 2300MHz
- RAM Type: DDR3 800MHz
- Hard Drive: 500GB
- Memory: 4GB
- Webcam: 0.3 Megapixel
- Battery Life: 4.33 Hours
- Brand Name: Toshiba
- Cache: 1MB
- Card Reader: 2 in 1 Media Card Reader
- DVD-RW Drive
- Graphics Card: Intel GMA 4500M
- Graphics Memory: Up to 1326MB shared
- Hard Drive Speed: 5400rpm
- Hard Drive Type: SATA
- Microphone: Built-in and External Port
- Network Card: 10BASE-T/100BASE-TX
- Networking Ports: 1 x Ethernet RJ45
- Operating System: Windows 7 Home Premium
- Speakers: Integrated Stereo Speakers
- USB Ports: 2
- Wireless Enabled: 802.11 b/g/n
Only £335.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) @ £34.79 inc VAT
Kingston's KHX1600C9D3X2K2/4GX is a kit of two 256M x 64-bit 2GB (2048MB) DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 4GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/4GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-27 2N
Capacity: 8GB (2GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Only £34.79 inc VAT.
ORDER NOW
