Creative Sound Blaster Z High Performance Gaming Sound Card - OEM (30SB150200000) @ £45.95 inc VAT
Experience every detail
A signal to noise ratio or SNR of 116dB delivers > 99.99% pure audio, which is 34.4 times better than typical motherboard audio.
Power up
The quad-core Sound Core3D™ audio processor offloads gaming effect processing from your primary CPU, improving your overall PC performance.
Live it, don’t just hear it
The SBX Pro Studio suite of technologies immerse you in awe-inspiring audio so you can experience games, music and movies in a 360-degree true-to-life sound stage over speakers or regular headphones.
Find them before they find you
‘Scout Mode’ allows you to hear your enemies from further away, giving you a distinct tactical advantage in combat.
Gear up for victory
There’s no longer any need to unplug your speakers to connect a gaming headset. The Sound Blaster Z series soundcards all features separate I/O so you can easily switch between hardware without having to unplug any gear.
Go Pro
Supports studio quality headphones and headsets of up to 600 ohm impedance.
Hook up for high fidelity audio
Single cable output to your home theatre system. Enjoy cinematic audio by transforming any source into immersive surround sound.
- Output Level (Full Scale): Front Channel Out : 2Vrms, Headphone (33 ohms): 1.3Vrms, Headphone (600 ohms): 2Vrms;
- Maximum DAC Resolution: Front Channel Out : 24-bit, 192kHz, Headphone (33 ohms): 24-bit, 96kHz, Headphone (600 ohms): 24-bit,
96kHz;
- SNR (20kHz Low-pass filter, A-Wgt), @ 24-bit, 96kHz: Front Channel Out : 116dB, Headphone (33 ohms): >105dB, Headphone (600
ohms): >105dB;
- Frequency Response @ 96kHz: Front Channel Out : 10Hz to 45kHz, Rear Channel Out : 15Hz to 45kHz, Center Out : 10Hz to 45kHz,
Headphone (33 ohms): 10Hz to 45kHz;
- Frequency Response @ 192kHz(Stereo only): Front Channel Out : 10Hz to 88kHz;
- Supported Output: Stereo/2.1 Speakers, 5.1 Speakers, Headphones;
- Headphone: 1 x Amplified 1/8" mini jack;
- Speaker Out: 3 x 1/8" mini jacks;
- Optical Out: TOSLINK;
- Optical In: TOSLINK;
- Line In / Microphone In: Shared 1/8" mini jack;
- Warranty: 1 Years Manufacturers Warranty;
Only £45.95 inc VAT.
ORDER NOW
_____
MicroLab FC330 56W 2.1 Speaker System - Dark Wood Finish @ £41.99 inc VAT
Beautiful wooden cabinet for perfect sound performance, the FC330 is a powerful 2.1 subwoofer speaker system. This system spots deeper bass and high fidelity speaker drivers for excellent performances. High quality tweeters and powerful woofer for your perfect music entertainment and enjoyment. Comes with front volume control and bass control for your preferred sound effects. Microlab premier range, the FC series is based on the FINE CONE designed by Acoustic expert, Peter Larsen. This design follows strict discipline in speaker designs to achieve perfect linear frequency response curve. Uncolored audio, precise position, and high resolution with Microlab own eAirbass technology
- Beautiful and powerful 2.1 subwoofer system with full range acoustic production
- X-Bass design, Microlab own proprietory technology - Bass with natural depth and range
- 5.25" Subwoofer system for deep vocal and bass effects and all natural wooden finish
- Designed by Denmark acoustic expert, Peter Larsen V12 FineCone technology with perfect linear response
- Front master volume and rear Bass volume controls
- Output power: 56 Watt RMS
- Power distribution: 16 Watt x 2 + 24 Watt
- Harmonic distortion: < 0.3% 1 W 1 kHz
- Frequency response: 35 Hz - 20 kHz
- Signal/Noise ratio: > 80 dB
- Separation: > 52 dB
- Input sensitivity: 360 mV
- Nominal impedance: 4 ohm
- Tweeter driver type: 3" x 2
- Tweeter rated power: 16 Watt
- Subwoofer driver type: 5.25" - X-Bass
- Subwoofer rated power: 24 Watt
- Frequency: 35 Hz - 20 kHz
- Output: 2RCA
- Input: 2RCA
Only £41.99 inc VAT.
ORDER NOW
Power up
Gear up for victory
Go Pro
96kHz;
ohms): >105dB;
ORDER NOW
_____
- Output: 2RCA
- Input: 2RCA
ORDER NOW
