**Today Only 04/05/2011** Coolermaster CM-690 II Lite Dominator Case £52.98 & Thrustmaster T500 RS G
22 Aug 2010
Coolermaster CM-690 II Lite Dominator Case - Black @ £52.98 inc VAT
The CM 690 II Lite raises the bar again, but with value for money, with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1x 120 mm (17 dBA)
- Rear Cooling: 1x 120 mm (17 dBA)
- Top Cooling: 2 x 140 / 120 mm (optional)
- Bottom Cooling: 2 x 120 mm (optional)
- HDD Cage cooling: 1x 120 mm (optional)
Only £52.98 inc VAT.
ORDER NOW
Thrustmaster T500 RS Simulator Racing Wheel for PS3 & PC (Licensed for Gran Turismo 5) @ £379.98 inc VAT
H.E.A.R.T. HALLEFFECT ACCURATE TECHNOLOGY™” is the name of the new technology developed by Thrustmaster to reproduce movements made on a product in games. It relies on magnetic – and not mechanical – 3D (HallEffect) sensors, placed in different locations according to the product in question. The precision made possible by the use of this technology is significantly higher than that provided by standard technologies. Another advantage of this system: by eliminating all friction, it guarantees zero mechanical wear, for permanent precision that won’t decrease over time. The level of precision is also enhanced by the absence of any dead zones: even the slightest movement made by the player results in a reaction. Actions in games are therefore more linear, smoother and without any untimely jolts.
- Authentic wheel: 30cm (12”) in diameter with brushed metal central spokes
- Authentic sequential gearshift levers: crafted of brushed metal, attached to the base (so they don’t move with the wheel)
- 17cm in height (for instant access along 1080°)
- Precision, Force Feedback & realistic angle of rotation
- New H.E.A.R.T Hall Effect AccuRate Technology™ on the wheel’s steering:
- Ultra-precise wheel, with 16-bit resolution (65536 values on the steering)!
- Precision that won’t decrease over time (contactless magnetic sensor)
- Force Feedback with industrial motor (Torque 150mNm, 3000rpm, 65W, Ø 52mm/2”)
- Super-powerful, quick responding Force Feedback mechanism
- Rigid motorized stopper, no matter what angle of rotation you select
- Mechanism with large dual belts (fluid and smooth action)
- Angle of rotation adjustable up to 1080° (3 full turns)!
- Realistic pedal set
- Unique design with your choice of 2 positions:
- Floor-mounted position (F1-style)
- Suspended position (GT-style)
- 100% metal, for optimal stability, weight (more than 7 kgs) and resistance
- 3 100% adjustable pedals (spacing between the pedals/height)
- Brake pedal with reinforced and adjustable resistance (included and removable “Realistic Brake” mod)
- Included metal footrest with non-slip grating texture
Only £379.98 inc VAT.
ORDER NOW
