- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
For the sunny warm weekend we have the following deals
XFX ATI Radeon HD 5770 Single Slot 1024MB GDDR5 PCI-Express Graphics Card @ £74.99 inc VAT
There’s an ideal graphics card for every gamer, and the XFX ATI Radeon™ HD 5770 single slot graphics card is for the gamer looking for “ility,” as in “utility,” “stability,” and “reliability,” not to mention some excellent overclocking “capability.” A single-slot card variant of the 5700 performance card family, it sports a uniquely designed fansink, with a total heatpipe surface area that is 15% greater than the HD 5770 dual slot channel fansink. This, combined with the open space provided by the single slot environment, ensures maximum airflow to the GPU.
An acoustic comparison of the 5700 family found that the XFX ATI Radeon HD 5770 single slot was up to 23.5 dB lower than the HD 5770 dual slot full cover fansink. Enhanced cooling and reduced noise is helped by fan speed, which is controlled by a PWM circuit on the PCB. Dust levels are kept down to a minimum with IP-5X dust protection standard. For gamers who have been waiting for the ideal single-slot graphics card, the XFX ATI Radeon HD 5770 has been worth the wait. The unique cooling capacity—and reduced noise levels—of this single-slot solution turns up the “ility,” making this a very attractive graphics card indeed.
- Single Slot Design!!
- Core Clock: 850MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Memory Bandwidth: 76.8GB/s
- Processing Cores: 800
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Warranty: 2 Years
Was £83.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) @ £199.99 inc VAT
As the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 120GB
- Controller: SandForce SF-2281
- Maximum Read: 550MB/sec
- Maximum Write: 500MB/sec
- Sustained Write: 500MB/sec
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £224.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £83.99 Inc. VAT
ORDER NOW
- Capacity: 120GB
- Warranty: 3 Years
ORDER NOW
