Today we have two great products to help improve your gaming and your gaming experience. Give plenty of power with Lepa W-Series 600W PSU or hear the enemy to the exact location with the Sennheiser PC 350 Pro-Gaming Headset.
Lepa W-Series 600W '80 Plus' Power Supply @ £56.99 inc VAT
Designed by engineers from CWT & Enermax combined these mid range PSU's are ideal for any gaming systems. Lepa are new to the power supply market, but the company behind Lepa are one of the best known PSU manufacturers in the world. You cannot go far wrong with any of the Lepa series PSU's.
- 80 PLUS® certified with peak 85% efficiency
- High efficiency 5Vsb circuit helps system to meet EU ErP Lot 6 2010 standby low power consumption requirements
- 12cm fan with thermal programmed speed controller providing silent cooling performance
- Active PFC universal switching circuit improves Power Factor value up to 0.99, reducing AC line reactive power loss to minimum level and automatically adopting AC voltage from 100~240V
- 8P PCI-E connector supplied supporting extreme graphic cards
- Protected by Over Power, Over Voltage, Over Current, Short-Circuit, and Brown Out protections circuits
- CPU 12V connector rail with >18A output to support next generation >6 cores processor structure
- Extended CPU connector cable to 60cm facilitates installation with bottom-mounted-PSU chassis
- SATA power connector with 3.3V rail to support new generation SSD
- 3 year warranty
Only £56.99 inc VAT.
ORDER NOW
Sennheiser PC 350 Pro-Gaming Headset (502141) @ £99.98 inc VAT
You’re gaming. Every frame is crucial. Just a fraction of a second could mean the difference between winning and losing. So pinpointing a sound’s origin in the game’s soundscape can give you the edge you need to beat your opponent. Developed for professional gamers, the PC 350 features a frequency response that’s so accurate, you can detect every sound’s exact location – and react before your opponents know what hit them. No advantage is unfair. Extra-large, circumaural velour ear pads keep you gaming in comfort over long stretches, blocking out background noise so you stay focused. And with an adjustable microphone boom and noise-canceling technology, you know your teammates will hear you clearly – whether you’re whispering instructions or screaming your success. Along with its advanced technology, the PC 350 features true plug and play convenience. A universal 3.5mm plug connects to your PC or laptop, so you can enjoy hard-core gaming, as well as music, movies and internet telephony – even at low volumes.
Combining comfort with the latest advances in sound technology,
the PC 350 makes defeating your opponent more fun than ever. The closed-speaker system and extra-large, circumaural ear pads block background noise, delivering precision sound for faster reaction times and a real advantage in the G4ME
Best possible sound quality and true 3D soundscape: its closed-type,
circumaural headset design and superior passive attenuation of ambient noise provide optimal sound quality as never before, superb binaural perception thanks to passive attenuation up to 32dB, patented Duofol diaphragm technology and adaptive baffle damping – so you can hear even the slightest movement before your opponents realize what hit them
Superb stereo: high-quality Sennheiser speakers deliver great stereo sound from your games,
music, movies and internet calls. Always intelligible: the noise-canceling microphone filters out ambient noise, so your voice will always be heard
Speech clarity: the microphone boom is adjustable so you can place the microphone just where you want it
- Headphone Type Circumaural, closed
- Speaker Type Dynamic, 38 mm, Nd magnet
- Frequency Response 10 Hz – 26,000 Hz
- Impedance 150 Ohms
- Sensitivity 108 dBSPL
- Distortion < 0.1 %
- Microphone
- Pick-up Pattern Noise Canceling
- Frequency Response 50 Hz . 16,000 Hz
- Sensitivity -38 dBV at 94SPL
- Cable Length 3 m
- Connectors Two 1/8” / 3.5mm plugs
Only £99.98 inc VAT.
ORDER NOW
- 3 year warranty
ORDER NOW
- Microphone
- Cable Length 3 m
ORDER NOW
