**TODAY ONLY! 05/11/2014** Creative Sound Blaster Z High Performance Sound Card & Logitech C170 5.0
OcUK Staff
4 Feb 2013
Creative Sound Blaster Z High Performance Gaming Sound Card - OEM (30SB150200000) @ £45.95 inc VAT
Experience every detail
A signal to noise ratio or SNR of 116dB delivers > 99.99% pure audio, which is 34.4 times better than typical motherboard audio.
Power up
The quad-core Sound Core3D™ audio processor offloads gaming effect processing from your primary CPU, improving your overall PC performance.
Live it, don’t just hear it
The SBX Pro Studio suite of technologies immerse you in awe-inspiring audio so you can experience games, music and movies in a 360-degree true-to-life sound stage over speakers or regular headphones.
Find them before they find you
‘Scout Mode’ allows you to hear your enemies from further away, giving you a distinct tactical advantage in combat.
Gear up for victory
There’s no longer any need to unplug your speakers to connect a gaming headset. The Sound Blaster Z series soundcards all features separate I/O so you can easily switch between hardware without having to unplug any gear.
Go Pro
Supports studio quality headphones and headsets of up to 600 ohm impedance.
Hook up for high fidelity audio
Single cable output to your home theatre system. Enjoy cinematic audio by transforming any source into immersive surround sound.
- Output Level (Full Scale): Front Channel Out : 2Vrms, Headphone (33 ohms): 1.3Vrms, Headphone (600 ohms): 2Vrms;
- Maximum DAC Resolution: Front Channel Out : 24-bit, 192kHz, Headphone (33 ohms): 24-bit, 96kHz, Headphone (600 ohms): 24-bit,
96kHz;
- SNR (20kHz Low-pass filter, A-Wgt), @ 24-bit, 96kHz: Front Channel Out : 116dB, Headphone (33 ohms): >105dB, Headphone (600
ohms): >105dB;
- Frequency Response @ 96kHz: Front Channel Out : 10Hz to 45kHz, Rear Channel Out : 15Hz to 45kHz, Center Out : 10Hz to 45kHz,
Headphone (33 ohms): 10Hz to 45kHz;
- Frequency Response @ 192kHz(Stereo only): Front Channel Out : 10Hz to 88kHz;
- Supported Output: Stereo/2.1 Speakers, 5.1 Speakers, Headphones;
- Headphone: 1 x Amplified 1/8" mini jack;
- Speaker Out: 3 x 1/8" mini jacks;
- Optical Out: TOSLINK;
- Optical In: TOSLINK;
- Line In / Microphone In: Shared 1/8" mini jack;
- Warranty: 1 Years Manufacturers Warranty;
Only £45.95 inc VAT.
ORDER NOW
_____
Logitech C170 5.0 Megapixal Webcam @ £14.59 inc VAT
With plug-and-play setup, VGA-quality video and a built-in mic, this webcam is the easy way to start video calling and send beautiful, high-resolution photos*.
Logitech webcam software:
- Pan, tilt, and zoom controls
- Video and photo capture
- Face tracking
- Motion detection
Specification:-
- Video calling (640 x 480 pixels) with recommended system
- Video capture: Up to 1024 x 768 pixels
- Logitech Fluid Crystal™ Technology*
- Photos: Up to 5 megapixels (software enhanced)
- Built-in mic with noise reduction
- Hi-Speed USB 2.0 certified (recommended)
- Universal clip fits laptops, LCD or CRT monitors
Only £14.59 inc VAT.
ORDER NOW
So does the fact that the OEM version doesn't have the EM shield suggest that the EM shield is just a cosmetic addition rather than actually doing anything?
Most probably. It looks like it doesn't have the stupidly bright annoying red leds that the retail version has either which is a good thing.
It's better and cheaper than the Recon 3d though. I ordered one anyway as thats a good price and the drivers for the onboard on my Hero are buggy as hell.
