**TODAY ONLY! 09/01/2015** NZXT H2 Classic Silent & SanDisk Extreme PRO 960GB SSD
OcUK Staff
4 Feb 2013
NZXT H2 Classic Silent Midi Tower Case - White @ £59.99 inc VAT
NOISE – chaotic wavelengths that distract, distort, impede, confuse, and endanger the gamer during a life and death situation. Intelligently constructed to give you peace of mind, NZXT’s H2 Classic Series Silent Midtower Chassis minimizes extraneous hums, clicks, whirls of your system to enhance your concentration, accuracy, and deadliness.
- Touch powered fans with fan filter for easy maintenance and fan swapping
- 30W 3-step fan control for airflow settings at 40%, 70%, and 100% of maximum fan speed
- Top hot swap capable SATA HDD Dock (requires an AHCI capable motherboard and hot swappable HDD) and USB 3.0 port for the most up to date function
- 8 Front facing HDDs for optimal airflow
- Noise dampening foam and a top magnetic fan cover for minimal PC noise
- Ample 25mm space behind motherboard for cable management
- Dimensions: 215 x 466 X 520 mm
- VGA Clearance Maximum: 310 w/o HDD, 250mm with HDD
- CPU Heatsink Support: 170mm
- Front Cooling: 2 X 120mm @ 1200rpm ( included )
- Rear Cooling: 1 X 120mm @ 1200rpm (included)
- Top Cooling: 1 X 140mm
- Bottom Cooling: 1 x 120mm
- Drive Bays: 3 x external 5.25" & 8 x Internal 3.5"/2.5" Slots
- Screwless Rail Design
- Expansions Slots: 7
- Motherboard Support: ATX, MICRO-ATX, BABY AT
Only £59.99 inc VAT.
ORDER NOW
_____
SanDisk Extreme PRO 960GB 2.5 Inch SATA 6Gbps Solid State Drive (SDSSDXPS-960G-G25) @ £279.98 inc VAT
Specifications
PCMark Vantage Score1: 81K
Sequential Read (up to): 550MB/s
Sequential Write (up to): 515MB/s
Random Read (up to): 100K IOPS
Random Write (up to): 90K IOPS
Super-charge your PC or game console with 24/7 consistent high performance from a global leader in Flash memory. Whether you’re a gamer or a media pro, SanDisk Extreme Pro® loads and runs your graphics-intensive applications blazing fast so you can spend your time doing instead of waiting. SanDisk’s innovative nCache™ Pro Technology optimizes read and write speeds and drive endurance and makes sure your data is stored in the safest place. Extreme Pro® SSD is engineered for efficient multi-tasking and workload management, low latency, and consistently fast computing. Easy to install, it runs cool, quiet and energy efficient, so your power bills are lower and your battery lasts longer. And it comes with a 10-year warranty.
Features Consistent high performance
No stall. No stutter. Innovative nCacheTM Pro Technology delivers extreme performance you can count on, every day, every week, every year.
Pro-level speeds
Extreme Pro® SSD delivers super-fast 550MB/s sequential read speeds so you can work, and play, with no delays.
Load and run in a heartbeat
Waiting for big, graphics-intensive apps and games to load is time you’ll never get back. With Extreme Pro® SSD, it’s time you never have to waste.
Trust your SSD. We do.
No other company stands behind their SSD for ten long years. Since we developed the world’s first Flash-based SSD more than 20 years ago, we have good reason to believe in our drives.
Always know what’s going on
With our SSD Dashboard, you always have visibility into how your drive’s performing, what firmware updates are available, and what you can do to maintain peak performance.
Embrace the green
With no moving parts, our SSDs run cool and quiet even when you use them hard. Your battery lasts longer on a single charge, and your laptop has a longer life—up to 33% longer.
Performance
Pro-level read and write speeds
Consistent 24/7 performance you can count on
Load and run games, video, 3D CAD and hi res photos blazing fast
Reliability
Engineered to optimize drive endurance
Huge storage capacities
SSD Dashboard reports drive status
Industry-leading 10 year warranty
Environmental soundness
Cool, quiet, energy-efficient operation
Lower power consumption
Up to 33% longer laptop life
Only £279.98 inc VAT.
ORDER NOW
I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,I don't need a new case,
Damn good price though :)
Do you need a new case, can't quite make out if you do or not? :p :D
apply some discount on the NZXT H440 and I'll take one of those off your hands instead ;)
the black and blue variant.
