**TODAY ONLY! 10/02/2015** LG Flatron 31MU97 31" True 4K 60Hz Professional Monitor & LG Flatron 34UC
OcUK Staff
4 Feb 2013
LG Flatron 31MU97 31" True 4K 60Hz Professional WideScreen LED Monitor - Black @ £899.99 inc VAT
When most consumers refer to ‘4K’, they’re actually referring to the UHD (Ultra High Definition) resolution of 3840 x 2160. This is, after all, the most common ‘4K’ resolution. It also maintains the common 16:9 aspect ratio and provides quite an enjoyable experience. The LG 31MU97 features a 4096 x 2160 resolution which is also referred to as ‘Digital Cinema 4K’ due to its use as the dominant 4K resolution by the DCI (Digital Cinema Initiatives). The monitor features LG’s robust ‘business-like’ stand which offers tilt and height adjustment but can’t be pivoted or swivelled.
This display uses a 31” AH-IPS panel (LM310UH1-SLA1) with a 4096 x 2160 resolution (17:9 aspect ratio) and 60Hz refresh rate. This features a very light matte (‘semi-glossy’) screen surface and is designed to provide accurate and consistent colours in both the sRGB and Adobe RGB colour spaces. It uses a flicker-free (‘Flicker Safe’ – PWM free) GB-LED backlight to provide this wide colour gamut (100% sRGB and over 99% Adobe RGB). The monitor is also factory calibrated for both of these colour spaces and features true 10-bit colour reproduction. It can be user-calibrated with the ‘LG True Color Pro’ software as well. ‘Reader’ modes also feature, which are ‘Low Blue Light’ settings allowing the user to select white point targets such as 3882K, 4300K or 4616K to cut down on the blue light emission.
The monitor features a wide range of ports, including; DisplayPort, Mini DisplayPort, 2 HDMI ports, 3 USB 3.0 ports and a 3.5mm headphone jack. The native resolution is supported at 60Hz over DP or MiniDP but only at 30Hz over HDMI. 5W stereo Maxx Audio speakers also feature, which seems to be a favourite on higher-end LGs at the moment. The included stand can be removed to reveal 100 x 100mm VESA holes.
Specification:
- Display Screen Size: 31"
- Aspect ratio: 17:9
- Panel Type: AH-IPS
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 4096x2160 (Only over DisplayPort at 60Hz)
- Response Time: 5ms (GTG)
- Color Support : 1B
- Viewing Angle (H / V ): 178 ° / 178 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz), 1x Mini-DisplayPort (60Hz)
- USB Hub: Yes (USB3.0)
- Speakers: Yes (5W Stereo)
- VESA: 100x100mm
- Height adjust, pivot, swivel stand
- Warranty: 2yr (On-Site with LG - 0344 847 5454)
Only £899.99 inc VAT.
ORDER NOW
_____
LG Flatron 34UC87-P 34" WideScreen Super-Wide Curved LED Monitor @ £799.99 inc VAT
21:9 Curved UltraWide QHD (3440*1440) display offers visual comfort with 2.4 times more visual information at one time than a Full HD monitor. And also, the QHD resolution’s 1440p vertical height allows you to use more vertically than a 29 inch 21:9 monitor.
IPS’s 178’ wide viewing angles, close to 180’, allow you to view the screen clearly without distortion. Also, the Curved IPS provides an immersive viewing angle covering the entire viewing angle around your range of vision.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or print through a sRGB over 99% colourspace and IPS’s accurate colour expression.
34UC87 provides two Thunderbolt2 ™ ports to directly connect a Mac PC and Pegasus2 storage directly to transmit data more than four times faster, than a USB 3.0. As a result, there is no concern of slow transmission from using a USB or HDMI connection. You can connect to various devices with the two HDMI and two USB 3.0 ports, and a Display Port. And, If you have a Mac, you can connect directly to the 34UC87 via Thunderbolt 2™, which transmits data more than four times faster than USB 3.0.
Using MaxxAudio® technology you will experience deeper bass and crystal clear highs. Equipped with two 7w internal speakers and MaxxAudio® technology, the 34UC87 provides cinema surround- like sound, allowing you to enjoy movies without any extra external speaker or sound output equipment.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Curve: 3800R
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Speakers: 2x 7W
- Height adjust stand
- VESA: 100x100mm
- Set with stand: 830.5 x 224.5 x 472.9
- Set without stand: 830.5 x 106.4 x 370.3
- Weight: 8.2kg
Only £799.99 inc VAT.
ORDER NOW
you pay for quality, considering 4k pro was at 3k not that long ago I don't think its too bad. In fact it really was not that long ago 1600p 30" pro screens were 1500+ either
4k ips with 10bit color with good response time and fully calibrated seems good actually
would be v nice, but ill stick to 1440p until HBM based 16nm GPUs hit the ground
