**Today Only 10/06/2011** OCZ Agility 3 120GB 2.5" SSD & Thermaltake Level 10 GT Visionary Full Towe
22 Aug 2010
Today we have yet again another 2 products with prices slashed. The level 10 GT is a case with a stylish twist. You won't really find a case with the same shape or unique look anywhere! The OCZ Agility 3 120GB SSD are blazing fast and perfect for a boot drive with plenty of space for a few games and your important files.
OCZ Agility 3 120GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-120G) @ £169.99 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 120GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 500MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £169.99 inc VAT.
ORDER NOW
Thermaltake Level 10 GT Visionary Full Tower Case - Black @ £199.98 inc VAT
Following the high-profile launch of Level 10 Super Gaming Modular Case, the design collaboration between Thermaltake and BMW Group DesignworksUSA, in 2009, Thermaltake looks to invigorate the PC enthusiasts with the latest Level 10 GT computer case. The design language of the Level 10 GT expresses a passion for visual aesthetics deriving from demanding and immersive game play and multimedia entertainment enthusiasm. Modern games and entertainment applications also require highly advanced hardware configurations, which at the same time request more space and optimized ventilation than conventional hardware. With EasySwap Pitstop 5 every HDD/SDD has its own removable tray, EasySwap in hot-plug mode within seconds. With this users have greatest storage flexibility and maximum data transfer speeds you need. Modern multimedia peripherals operate at tremendous data transfer velocities, with 2 USB 3.0 connectors right on the top of the Level 10 GT you be guaranteed to always enjoy SuperSpeed entertainment. The concept of the clear lines of the outside design of the Level 10 GT is just as well continued in the inside. An advanced and highly convenient cable management bundles respective cables almost like in tunnels behind a back plate. Your system shines in clarity, easy access to all components is warranted for and even ventilation is greatly improved. High tech components are prone to heat impacting longevity and performance. For this vital reason the implementation of Thermaltake's QuadFan (of which three also feature ColorShift) Ventilation concept creates an ideal environment for your components to unfold their full potential. Perception of what and how it is surrounding us, can have strongly inspiring, motivating and vitalizing effects on us. With triple ColorShift three LED fans with five sets of illuminations let you get into the driver seat of your respective moods. Or if so wanted, you turn them all entirely. At times enthusiasm may push you to the ultimate limits, to where you have not been before. Particularly for those who are bound to go beyond these restrictions, i.e. tune and clock your setting, further measures to keep the heat down might be asked for. Ready for Liquid Cooling Systems you can rest assured to keep your coolness. Powerful performance needs space to unfold, this is also the case for highly advanced graphics cards, which the length has grown considerable over the past years and is most likely to grow even further in the future. With space for up to 37 cm oversized cards, there is sufficient space to stay future proof.
- Performance cooling made quiet: one top 200mm exhaust fan, one front 200mm intake fan, one side 200mm intake fan and one rear 140mm exhaust fan.
- Hinged side panel to enable easier opening of the side door and access to computer for maintenance or upgrade.
- Dramatically improved cable management. User no longer "hides" the excessive cable on the back, the Level 10 GT features numerous holders designed into the chassis for cable management.
- Five hot-swappable hard drive bays, each with its dedicated backplane to support hot-swap. Hard drive mounting supports both 2.5" or 3.5" drives.
- Connectivity array. Four USB 2.0 ports are conveniently located on the front bezel including a pair of audio ports. Two USB 3.0 ports and one eSATA port located on the top.
- Water cooling ready - 120mm or 240mm radiators can be easily attached to the top side of the chassis (top 200m fan needs to be removed)
- Fan speed management control embedded. ColorShift fans can be easily controlled through controls on the top.
- Fully black-powdered interior.
Only £199.98 inc VAT.
ORDER NOW
jaw dropping price for the ssd.... :( damn not got enough money for it .... a bargin compared to the price i paid for the number 2 version at 200 buck.... i`m pretty sure this will be sold out within hours....
Pity the poor marketing person who had to come up with something to try and justify people buying something that looks like a dog's dinner.
Are the Agility 3's the original firmware or have SF/OCZ updated the firmware to fix the issues some people (myself included) were having with the first batch?
OCZ says SF working on a fix. They have issues(at least ocz says less than 1% have issues) on firmware version 2.02 and 2.06. All the latest shipped from OCZ already comes with 2.06. My ocz agility 3 has "issues" as well.
I know only too well, 2 out of the 3 I bought had problems.
Yellowbeard (Corsair rep) has posted on this forum that they are already replacing affected drives with a fixed version, hence my question for the OcUK team.
I was advised by OCZ (via email) and crucial (phone) not to use SATAIII 6gb/s drives in ICH9R chip sets, because of having compatibility issues.
Also rang up 2 OCUK competitors as some SSDs can be had for cheaper, they both advised the same. May be they should put it in the product description, just as they put "backward compatible with SATAII"
So zero issues with Sandybridge?
Its all very confusing with Corsair withdrawing their range and OCZ doing pretty much nothing. I bet this is doing nothing for sales.
well my 2nd SSD ordered now, as is the rest of my upgrades. going to be abit of a jump going from my current rig to a 2600k/Z68 UD5 and raid agility 3's as a boot drive (samsung F4 320gb as my boot atm)
going to be a fun build :D
Well I wouldn't say zero :) I spent last few days trying to find out whats wrong with my SSD and there are many sandy users with unhappy posts in ocz forums. But then again it is only unhappy ones that posts there ;)
Hopefully yours will be. I just had a week of frustration as first one drive then a second ordered a few days later failed in an array or disappeared in IRST/BIOS before I finally sent all three drives back and picked up the tried and tested Vertex drives on Epic Tuesday. They're now flashed to Vertex Turbo firmware and haven't missed a beat. As I'm still on SATA 3Gb/s I'm not losing any sleep over the difference and I've saved a packet.
Still, all the uncertainty over the reliability of these new drives is clearly driving the price down, which is no bad thing.
Well it be a couple of weeks till get to that stage of the build, The stuff is being sent to work as I'm on my holidays plus this will be a new case and redo of my watercooling loop so not quite a quick one even build.
So by then I hope there be a firmware update or two and I plan to keep my Samsung 4 320gb as a backup of the SSD's raid (which will be my frist raid array I mite up.
