**TODAY ONLY! 10/11/2014** Silverstone Redline RL01 Gaming Case & Zalman ZM-MIC1 Microphone
OcUK Staff
4 Feb 2013
Silverstone Redline RL01 Gaming Case - Black (SST-RL01B USB 3.0) @ £17.99 inc VAT
The Redline series was created with the goal of exceeding user experience and expectation for affordable PC chassis by offering punchy styling and features reserved often for more expensive models. The RL01, with its armed front fascia punctuated by glowing red SilverStone logo that doubles as a power button and red LED fan has an exciting presence that will surely raise the adrenaline of PC enthusiasts. Its bottom mounted power supply layout and flexible drive storage options enable it to support a wide selection of components. The top, front, and the bottom side of the RL01 are also fully filtered to ensure that positive pressure setup, a prominent feature in SilverStone’s high-end chassis, is a viable option for creating a dust-proof PC. For enthusiasts looking to build a PC with quality features and styling on a budget, the RL01 is an excellent choice.
- Fantastic styling details with glowing button and red LED fan
- Positive pressure design for effective dust reduction
- Removable magnetic dust filter for top and bottom vents
- Smart backside cable routing design
- Motherboard back plate opening for quick CPU cooler assembly
- Support easy access drive bays with tool-less design
- Drive Bay: External 5.25" x 3 / 3.5" x 1
- Internal: 3.5" x 5, 2.5” x1
- Cooling System: Front 1 x 120mm red LED intake fan
- Rear: 1 x 120mm fan slot
- Top: 2 x 120mm or 1 x 120mm and 1 x 140mm fan slots
- Bottom: 1 x 120mm fan slot
- Expansion Slots: 7
- Front I/O Port: USB 2.0 x 2 / USB 3.0 x 2 / Audio x 1 / MIC x 1
- Power Supply: 1 x optional standard PS2(ATX)
- Expansion Card: Compatible with expansion cards up to 11”
- Limitation of CPU cooler: 155mm
- Limitation of PSU: Unlimited
- Net Weight: 5.1kg
- Dimension: 192.5mm (W) x 440.3mm (H) x 485mm (D), 42.0 liters
Only £17.99 inc VAT.
ORDER NOW
______
Zalman ZM-MIC1 Microphone @ £3.95 inc VAT
Zalman ZM-MIC1 is a highly sensitive microphone with a clip for ease of use, some high quality headsets do not have microphones and in this case Zalman have come up with an easy solution.
Features:-
- High Sensitivity Headphone Mic
- 3 Mini Clips for Tidy Arrangement
- Attractive & Compact Design
Specification:-
- Sensitivity: -40 ± 3dB
- Impedance: Max. 2.2
- Standard power supply: 2.0 V DC
- Current consumption: Max. 0.5 mA
- Sensitivity reduction: Within-3dB at 1.5V
- S/N: More than 58dB
- Directivity: Omnidirectional
Only £3.95 inc VAT.
ORDER NOW
Cheap case is cheap.... But I've ordered one just to build a system from spare parts and then sell !
Great price with the free shipping :) :)
