BitFenix Alchemy Cable Bundle – Black @ £21.95 inc VAT
BitFenix are leading in cables, cases and modifications with PC components, this bundle includes cable set within the same colour to keep a consistent look within your case and give it the professional look.
Bundle Includes:-
- 1x 24-Pin ATX Extension
- 1x 8-Pin EPS12V Extension
- 1x 8-Pin PCIe Extension
- 1x 6-Pin PCIe Extension
Only £21.95 inc VAT.
ORDER NOW
_____
BitFenix Alchemy Premium Modding LED Strip - Connect Green 60cm @ £12.00 inc VAT
Part of the BitFenix Alchemy Premium Modding Series, Alchemy LED Strips are the ideal choice when modding inspiration strikes. These precision manufactured LED Strips come with BitFenix TriBright™ LED Technology for the absolute brightest LED strips available. Alchemy LED Strips come in both chainable Connect and waterproof Aqua, and offer a multitude of lengths and colors, enabling you to bring your modding vision to light.
When only the brightest will do, BitFenix TriBright™ LED Technology gives you the industry’s brightest LED strips. TriBright uses independent ICs to power each LED bulb for maximum brightness.
Alchemy LED Strips are made using a precision SMT manufacturing process, which means the highest quality, enhanced current conduction, and prolonged life.
Have a special idea that needs an extra-long length of LED strips? No problem. With Alchemy Connect LED Strips, you can connect as many strips together as you need with the only limitation being your power supply's current.
BitFenix Alchemy LED Strips are backed with high-grade adhesive from 3M™, which makes sure that your LED strips will remain where you left them, even when your computer is being moved around.
- Colour: Green
- Length: 60cm
- LEDs: 30
Only £12.00 inc VAT.
ORDER NOW
Bundle Includes:-
ORDER NOW
_____
- Colour: Green
- Length: 60cm
- LEDs: 30
ORDER NOW
