**TODAY ONLY! 13/10/2014** Crucial MX100 256GB SSD & Netgear Nighthawk X4 Smart Wifi Router
OcUK Staff
4 Feb 2013
Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) @ £74.99 inc VAT
The Crucial MX100 SSD makes your computer faster and more efficient – at a price that will make you think twice about getting a hard drive
The choice between speed and capacity is over. Choose both.
Traditionally, SSDs have offered powerful speeds and extra features, but at a high cost per GB. Not so with the Crucial® MX100 SSD. Leveraging years of R&D and the latest NAND technology, the Crucial MX100 delivers a low cost per gigabyte, combined with unrelenting performance and one of the most complete feature sets available. With the Crucial MX100, boot up and load programs almost instantly, accelerate demanding applications, and encrypt and protect everything on your computer.
Every MX100 includes a download of Acronis True Image 2014 OEM Edition PC Backup and Recovery, Please note the download code is under the internal packaging tray.
The Crucial MX100 provides plenty of cost-effective storage for your photos, music, videos, and documents—all while backing your data with a higher level of reliability than a hard drive or competing SSD.
Run your system longer than ever before—using less power.
With Extreme Energy Efficiency technology, the Crucial MX100 is up to 89% more energy efficient than a typical hard drive.
Keep your memories, photos, and files safe.
When a photo or file gets corrupted, it often becomes unusable. Prevent this from happening in the first place with the Crucial MX100 SSD, which arms every storage component with four layers of Exclusive Data Defense to guard against corrupt files.
Protect all of your data—even if the power goes out.
With Power Loss Protection, if you happen to be saving a file and you suddenly lose access to power, your data will still be preserved.
Push your drive to the limit and avoid overheating.
Adaptive Thermal Protection technology enables the Crucial MX100 to dynamically adjust storage component activity based on how you’re using the drive, allowing your system to stay cool and react to changes in use.
Sequential Read2
550 MB/s
Sequential Write2
330 MB/s
4KB Random Read2
85,000 IOPS
4KB Random Write2
70,000 IOPS
Type
2.5 Inch
Height
7mm (with 9.5mm adapater)
Memory Type
Micron 16nm MLC NAND
Controller
Marvell® 88SS9189 with Micron® Custom Firmware
Interface
SATA 6Gbps (SATA III)
MTTF
1.5 million hours
Warranty
3 Years
Endurance
72TB Total Bytes Written (TBW), equal to 40GB per day for 5 years
Operating Temperature
0°C to 70°C
Hardware Encryption
AES-256 encryption engine, TCG Opal 2.0 compliant, IEEE-1667 complaint, Microsoft® eDrive® compatible
Advanced Features
Native Write Acceleration, Redundant Array of Independent NAND, Multistep Data Integrity Algorithm, Adaptive Thermal Protection, Power Loss Protection, Data Path Protection, Active Garbage Collection, TRIM Support, Self Monitoring and Reporting Technology (SMART), Error Correction Code (ECC)
Compliance
CE, FCC, BSMI, C-Tick, VCCI, Kcc, RoHS, China RoHS, WEEE, TUV, UL, SATA-IO
Only £74.99 inc VAT.
ORDER NOW
________
Netgear Nighthawk X4 AC2350 Smart WiFi Router 4 Port Gigabit Switch 2 x USB 3.0 ( @ £209.99 inc VAT
Features:
• Quad-Stream AC2350 WiFi – up to 2.33Gbps (600+1733 Mbps)
• Next generation Wave 2 WiFi
• Fastest available 1.4 GHz dual core processor
• Dynamic QoS bandwidth prioritization by application and device
• Twin USB 3.0 and eSATA ports to connect external storage and enjoy fast, wireless access to high-capacity hard drives
• Four high-performance external antennas and Beamforming+ for maximum range
• Manage your home network with NETGEAR genie
X4 Architecture
Be ready for the next generation of WiFi and optimize bandwidth utilization. Introducing Quad-Stream X4 Architecture, delivering the single fastest WiFi connection available, up to 1.73Gbps, with a combined speed of 2.33Gbps.
Dynamic QoS
Reduce buffering and lag while gaming or streaming. Based on an advanced application and device aware prioritization technology, Dynamic QoS intelligently allocates bandwidth to the most important activities in your home.
Faster Processing
Make sure you have enough processing power to run all the network-heavy applications throughout your connected home. With an unmatched 1.4GHz dual core processor, you'll have unparalleled performance for gaming, streaming and mobile connectivity.
Storage
The twin USB 3.0 ports and eSATA port provide speed and flexibility when you connect your external storage to your Nighthawk X4. Enjoy fast, wireless access to your high-capacity hard drives from anywhere. Then keep it safe with free ReadyShare Vault PC software and schedule automatic hassle-free backups to safeguard precious photos and files from any PC directly to the connected USB storage.
Speed
Get the single fastest WiFi connection with X4 Architecture for a blazing-fast, lag-free WiFi experience.
• World's Fastest WiFi—Up to 2.33Gbps combined WiFi speed for extreme gaming and streaming (600+1733 Mbps)
• Quad Stream X4 Architecture —Single fastest WiFi connection
• Gigabit wired—Ideal for HD gaming and video
• Gigabit WiFi—Next-generation WiFi now at Gigabit speeds
• Dual core processor—Dual Core 1.4GHz processor boosts wireless, wired, WAN-to-LAN, and network storage performance
WiFi Range
Homes come in all shapes and sizes and the Nighthawk X4 provides WiFi coverage no matter where you connect in your home.
• Ultimate range—WiFi coverage throughout very large homes
• Antennas—High-powered amplifiers and four high-performance external antennas
• BEAMFORMING+—Boosts speed, reliability, and range of WiFi connections
Reliability
There’s nothing more frustrating than lost connections. With Nighthawk X4 advanced features and best-in-class WiFi technology, you’ll reduce interference and enjoy more reliable connections.
• Simultaneous Dual Band—Reduces interference for better connections to more WiFi devices
• Dynamic QoS—Delivers bandwidth prioritization by application and device
• Beamforming+ — Focuses WiFi signals for stronger more reliable connections on 2.4 and 5GHz bands
Sharing
Sharing across your network is fun and easy. Anything from accessing stored photos and music to sharing a USB printer and keep everything safe by using the included FREE ReadySHARE Vault software for backing up Windows-based PCs.
• ReadySHARE® USB access—Wirelessly access and share USB hard drive and printer via two (2) superspeed USB 3.0 ports, up to 10x faster than USB 2.0
• eSATA port—Access to high-speed and high-capacity external hard drives
ReadySHARE Vault—Free software for automatic PC backup to a USB hard drive connected to the router
• DLNA®—Find and play your media on DLNA TVs, game consoles and media players
• ReadySHARE Printer—Wirelessly access and share a USB printer
• Personal FTP server—Customized free URL to create FTP server
Ease of Use
Start enjoying your new Nighthawk X4 faster than ever. NETGEAR makes sure installation and management is simple and easy, so you can connect quickly and stay that way.
• Easy install—Easy setup for iPad®, tablets, smartphones and computers
• NETGEAR genie® App—Personal dashboard to monitor, control and repair your home network from a smartphone, tablet or computer
• Push ‘N’ Connect—Easy push button WiFi connections (WPS)
• WiFi and power on/off—Convenient power savings
• LED on/off—Easily turn router LED lights on or off
Security
The highest security across your network ensures your privacy and family is safe while online. Whether it’s preventing phishing and spyware or just limiting access for kids and household guests, NETGEAR has you covered.
• VPN support—Secure access to your home network when away from home
• Parental controls—Web filtering for all your connected devices
• Guest network access—Separate and secure access for guests
• Secure WiFi connections—Highest-level wireless security with WPA/WPA2
• Open source support—Download open source firmware from www.myopenrouter.com
Only £209.99 inc VAT.
ORDER NOW
I have the R7000 with 3 aerials and can handle lots of devices and streams at once. Much better pings than my old one. The R8000 has 6 aerials and looks even madder!
May have bought this but it's 'fat ass' leads to being used flat on your desk, I always mount mine on the wall.
Btw how's Netgear for security and stability these day?
