**TODAY ONLY! 13/11/2014** Mionix Avior "SK Gaming" Pro Gaming Mouse & Zowie Celerita Pro Gaming Key
OcUK Staff
4 Feb 2013
Mionix Avior 'SK Gaming' Professional Gaming Mouse - FREE SK GAMING SURFACE WORTH £25 @ £59.99 inc VAT
The official gaming mouse of SK Gaming, the AVIOR SK is a premium 9 button ambidextrous mouse. The unique ergonomic shape has been developed to be used by either right or left-handed gamers, and to support a palm or claw grip.
The ADNS-3310 gaming grade optical sensor delivers no positive or negative hardware acceleration, amazing accuracy, smooth tracking, and a maximum speed of more than 5.45m/sec (215 IPS) all the way up to 7000DPI.
With the new lift off distance (LOD) Calibration feature we have combined the Surface Quality Analyzer Tool (S.Q.A.T ™) with adjustment of the lift off height to find the lowest possible LOD with optimized tracking.
The lightning fast 32bit ARM™ processor enables the mouse to have many features without compromising the tracking of the sensor. The downloadable software provides access to fully customize all buttons, sensor settings, LED colors, macros and profiles.
Ambidextrous design
Supported shape for use by both right and left handed gamers.
Palm or Claw grip
Suited to both Claw and Palm style grips
Angle Tuning
You can adjust the X/Y rotation angle to counter your hand sweep angle, to
improve your accuracy.
Product Specification:
- 32bit ARM processor running at 32Mhz
- Ambidextrous design, palm or claw grip
- Soft touch rubber coating
- 9 fully programmable buttons
- 3 step in-game DPI adjustment
- 2 integrated RGB LEDs in 2 color zones
- Up to 16.8 Million LED color options
- Lighting effects Color shift, Solid, Blinking, Pulsating and Breathing
- 128 kb built-in memory
- Polling rate adjustable up to 1000Hz
- Large PTFE mouse feet
- Gold Plated, Full speed USB 2.0 connection with Plug and Play
- Cable 2m long braided cable
- 2 years manufacturer warranty
Sensor Specification:
- ADNS – 3310 gaming grade IR-LED optical sensor
- Up to 7000DPI
- MAX tracking speed of at least 5.45m/sec (215 IPS)
- No positive or negative hardware acceleration
- Adjustable Lift Off Distance
Only £59.99 inc VAT.
ORDER NOW
______
Zowie Celeritas Pro Gaming Keyboard (MX Red), Black - UK Layout @ £59.99 inc VAT
Technical details:
- Dimensions: 440 x 37 x 162 mm (W x H x D)
- Color: Black
- Weight: 1,2 kg
- Layout: English
- Switches: Cherry MX Red
- Connections:
USB (gold-plated)
PS2 adapter included
Cable length: 1.8 m
Repetition time:
32 ms 1x =
2x = 16 ms
8 ms = 4x
8x = 4 ms
Features:
Compact design (space-saving)
Very sturdy construction with metal frame
Anti-Ghosting: 6x USB / PS2 full with
adjustable repetition time (4 steps)
Selectable Logo Illumination: Blue / Red
multimedia keys
ORDER NOW
