Today Only,
we have 2TB of Fast, Green SATA 6Gb/s Storage for less than £50 inc VAT which has fantastic performance and perfect for a backup drive to keep your important media and files safe. We also have the Zaward Vapor 120 which offers excellent cooling properties and is supplied with a 120mm fan.
Hitachi Deskstar 5K3000 2TB SATA 6Gb/s 32MB Cache 5900RPM - OEM @ £49.99 inc VAT
The Deskstar™ 5K3000 is Hitachi’s first hard drive to deliver an enormous two terabytes of storage capacity and 5900 RPM performance in a standard 3.5-inch form factor. The 5K3000 is also one of the first Hitachi hard drives with a 6Gb/s SATA interface, which along with its 32MB cache buffer delivers a big boost to performance over the previous generation product.
- Backwards compatible with SATA-II
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA 6Gb/s
- Spin Speed: 5900RPM
- Warranty: 3 Years
Only £49.99 inc VAT.
ORDER NOW
Zaward Vapor 120 Multi Socket CPU Cooler (Socket: LGA775/LGA1156/LGA366/AM2/AM2+/AM3/754/939/940) @ £22.98 inc VAT
The Zaward Vapor 120 offer excellent cooling properties and is supplied with a single golf ball style 120mm fan, you can fit a second fan to this heatsink to improve the cooling performance even further using the tried and test push-pull method.
- Socket: LGA775 / LGA1156 / LGA1366 / AM2 / AM2+ / AM3 / 754 / 939 / 940
- Dimension: 20 (W) x 50 (D) x 160 (H) mm
- Fin: Aluminum alloy with 3 x 8mm copper heatpipes
- Base: Aluminum with H.D.T
- Dimension: 120 x 120 x 25 mm
- Bearing type: Long life Duro bearing
- Speed: 300±200 rpm ~ 2000±10%
- Air flow: 93.96 CFM max.
- Noise level: 10~34.3 dBA
- Connector: 4 pin with PWM function
- LED: 4 blue
- Life Expectancy: 60,000 hours
- Thermal resistance: 0.15 °C/W
- Weight: 684g
Only £22.98 inc VAT.
ORDER NOW
- Capacity: 2TB
- Cache: 32MB
- Warranty: 3 Years
ORDER NOW
- LED: 4 blue
- Weight: 684g
ORDER NOW
