**Today Only 17/03/2011** Samsung P2370 23" Widescreen LCD Monitor & G.Skill RipJawsX 8GB 1600MHz
22 Aug 2010
Today Only, we have 10 units of Samsung P2370 23" Widescreen LCD Monitor - Glossy Black for only £119.99 inc. VAT. Ultra-slim and ultra-elegant, the Touch of Colour design is inspired by the artistic integrity of hand blown glass. The translucent charcoal gray gradation of the bezel and cobalt blue hues of the clear crystal neck subtly shift in color depending upon external light conditions, creating an exquisite interplay between the monitor and the environment that it is placed in.
We also have 30 units of G.Skill RipJawsX 8GB 1600MHz DDR3 Memory for just £71.99 inc. VAT. Combined with the Intel’s highly anticipated Sandy Bridge platform, G.Skill RipjawsX series memory kits deliver more bandwidth and performance than ever.
Samsung P2370 23" Widescreen LCD Monitor - Glossy Black @ £119.99 inc VAT
Ultra-slim and ultra-elegant, the Touch of Colour design is inspired by the artistic integrity of hand blown glass. The translucent charcoal gray gradation of the bezel and cobalt blue hues of the clear crystal neck subtly shift in color depending upon external light conditions, creating an exquisite interplay between the monitor and the environment that it is placed in. The ultra-slim 30mm depth not only creates more style in less space but also ensures exceptional all round efficiency. Up to 50% slimmer than traditional monitors, the modern, organic contours gently accentuate the elegance of your lifestyle and home.
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 50000:1
- Brightness: 250cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x DVI-D (HDCP Compliant)
- Dimensions: 571.0mm x 423.0mm x 190.0mm
- Weight: 4.1kg
- Warranty: 3 Years On-Site
Only £119.99 inc VAT.
ORDER NOW
G.Skill RipJawsX 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-8GBXL ) @ £71.99 inc VAT
G.Skill has announced the development of its brand new RipjawsX series memory modules, designed specifically for Intel Sandy Bridge LGA1155 processors, and H67 and P67 motherboard platforms. The new RipjawsX series consists of a complete range of memory solution, from DDR3 1,333MHz, 1,600MHz, 1,866MHz, 2,133MHz, 2,200MHz to 2,300MHz. Combined with the Intel’s highly anticipated Sandy Bridge platform, G.Skill RipjawsX series memory kits deliver more bandwidth and performance than ever.
Building on the strong success of the first generation Ripjaws brand in performance memory kits, every single RipjawsX memory kit is hand-tested on an Intel Sandy Bridge platform in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology!The following list shows the detail specifications of G.Skill RipjawsX family.
Model Name: F3-12800CL9D-8GBXL
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-24 2N
Capacity: 8GB (4GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.5V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Only £71.99 inc VAT.
ORDER NOW
Second time I've seen that Samsung at this price, its amazing value, all the reviews confirm stunning build and picture quality.
I cant buy it though, it doesn't have portrait swivel & vesa mount. :(
