**TODAY ONLY! 17/11/2014** Xigmatek Mach Midi-Tower & BitFenix Colossus M Mini-ITX Cube
OcUK Staff
4 Feb 2013
Xigmatek Mach Midi-Tower Black @ £19.99 inc VAT
From the beginning we had a vision which was to include all the latest technology without the hefty price tag. Mach was designed with the most up to date technology such as USB3.0 x 2, tool-less 3 x External 5.25”bays, 3 x internal 3.5” bays or 4 x 2.5” bays. Another great feature that would impress gamers and over-clockers is that Mach will allow installation of up to 390mm graphic cards and up to 165mm tall CPU coolers which is an added bonus for all the enthusiasts.
- Designed with a sense of speed and power
- Racing stripes/grill works as a top exhaust function
- Supports 390mm top of the range full-length gaming graphics cards.
- Supports 3 x 5.25”, 3x 3.5” or 4 x 2.5” drive bays
- 2 x USB 3.0 compatibility
-165mm clearance for CPU cooler
-Includes two pre-installed high performance silent Xigmatek 140mm LED fan with FCB (Fluid Circulative Bearing) for ultimate exhaust capabilities.
Specifications:-
- Dimensions: 180 x 405 x 410 mm (W x H x D)
- Material: SECC (Body), plastic (front cover)
- Color: Black
- Form Factor: ATX, Micro-ATX, Mini-ITXB
- Total fan possible:
- 2x 120 mm (front)
- 1x 120 mm (rear)
- 2x 120 mm (right side panel)
- 1x 120 mm (cover)
Thereof pre-installed:
- 1x 120 mm (back side; XLF Series White LED)
- Drive Bays:
- 3x 5.25 inch (external)
- 3x 3.5 inch (internal)
- 4x 2.5 inch (internal)
- Power supply: 1x Standard ATX (optional)
- Expansion Slots: 7
- I / O Panel:
- 2x USB 3.0 (internal connection)
- 1x per Audio In / Out
- Maximum video card length: 390 mm
- Maximum CPU cooler height: 165 mm
Only £19.99 inc VAT.
ORDER NOW
_____
BitFenix Colossus M Mini ITX - Black @ £55.99 inc VAT
The spacious interior offers two preinstalled 120mm front and rear fans, and includes the option to install up to five 120mm fans for extra cooling boost. Up to five 3.5" drives or seven 2.5" drives in total can be installed, or for those looking to run high-end graphics cards up to 330mm, the 3 bay FlexCage™ can be easily removed. Colossus Mini-ITX supports installation of thick 240 mm radiators on the top or front, and the easily removable bottom dust filter prevents from dust accumulating dust inside the case over time. Colossus Mini-ITX is the perfect choice for enthusiasts who are looking for compact stylish case with excellent water cooling support and massive storage options.
Features:-
- Futuristic Form – Bold lines with a compact design
- LiteTrak™ Technology – Smooth multimode lighting with three colors and an included pulse mode
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- Maximum Storage Potential – Five 3.5" HDDs or eight 2.5" SSD locations available
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Friendly Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
Specification:-
- Materials: Steel, Plastic, SofTouch™
- Colors (Int/Ext): Black/Black
- Dimensions (WxHxD): 250 x 330 x 374mm
- Motherboard Sizes: Mini-ITX
- PCI Slots: x 2
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: LiteTrak™ lighting system, SofTouch™ surface treatment, tool-free drive locking mechanisms, filtered intakes
Drives:-
- 5.25" Drive Bays: x 1
- 3.5" Drive Bays: x 5
- 2.5" Drive Bays: x 8 (5 + 2 + 1 )
Cooling:-
- Top: 120mm x 2 (optional)
- Front: 120mm x 2 (1 included) or 140/180/200/230mm x 1 (optional)
- Rear: 120mm x 1 (included) or 140mm x 1 (optional)
I/O:-
- USB 3.0 x 2, HD Audio
Only £55.99 inc VAT.
ORDER NOW
