**Today Only 18/03/2011** Coolermaster CM-690 II Advanced Dominator Case & Corsair Hydro H50-1 CPU
22 Aug 2010
Today Only, we have 15 units of Coolermaster CM-690 II Advanced Dominator Case - Black for only £69.99 inc. VAT. The CM 690 II Advanced raises the bar again with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter.
We also have 30 units of Corsair Hydro H50-1 High-Performance CPU Watercooler for just £49.49 inc. VAT. The Corsair Hydro Series™ H50 CPU Cooler gives you the power of liquid cooling in a compact, easy to install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
Coolermaster CM-690 II Advanced Dominator Case - Black @ £69.98 inc VAT
The CM 690 II Advanced raises the bar again with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- External SATA HDD dock
- Includes SSD Adapter
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1 x 140mm Blue LED Fan
- Rear Cooling: 1 x 120mm Fan
- Top Cooling: 1 x 140mm Fan
- Bottom Cooling: 2 x 120mm Fans (optional)
- Right Side Cooling: 2 x 120 or 140mm Fans (optional)
- Left Side Cooling: 1 x 80mm Fan
- HDD Cage Cooling: 1 x 120mm Fan (optional)
- VGA Holder: 1 x 80mm Fan (optional)
Only £69.98 inc VAT.
ORDER NOW
Corsair Hydro H50-1 High-Performance CPU Watercooler (Socket LGA775/1155/1156/1366/AM2/AM3) @ £49.49 inc VAT
The Hydro Series H50 goes head-to-head with top of the line heatsinks, but maintains the near silence of liquid cooling for annoyance-free cooling performance. Due to its compact form factor, the H50 is the ideal solution for any case with a 120mm fan mount, even small form factor cases that prevent the installation of traditional heatpipe based air coolers. So whether you want world-class cooling, lower noise levels than your current CPU cooler, or something that fits in your small form factor case, the closed-loop Hydro Series H50 takes your CPU’s temperature to new lows and takes up less room doing it.
- Pre-filled, closed-loop system is easy to install
- Copper CPU cooling plate for maximum cooling performance
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection
- Large 120mm radiator for fast heat dispersion
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator
- Two-year warranty
Only £49.49 inc VAT.
ORDER NOW
Ahhh no fair. I wanted the H50-1 cooler but now have lack of funds until next Friday. Guess I will have to buy it at full price next week. But good deal. Ooooh, unless you stick it in TWO next week :D
If I didn't just take 3 days to get my dang Freezer 7 Pro Rev 2 seated right I would be all over that cooler :/ Oh well maybe next time.
I think everyone knows that I love this case. Very tidy and easy to cable manage. Few small niggles here and there but no more then any case really. One main niggle is that I would have liked rubber gromets around the cable management holes, but its such a small thing.
The CM-690 II is a really nice case, one of the better looking cases if you ask me.
It's also a great price too.
I will certainly buy one of these for my build, but I will have to wait a bit longer, hope they will be on offer again in April... hint hint:)
