**TODAY ONLY! 18/11/2014** Team Group X101 32GB USB3.0 Flash Drive & Arozzi Torretta Gaming Chair
OcUK Staff
4 Feb 2013
Team Group X101 32GB USB 3.0 Flash Drive - Silver (TX101332GS01) @ £9.98 inc VAT
Based on USB 3.0 technology, Team X101 USB 3.0 flash drive is originally designed with feature ultra-high transmission speed in mind. Its metal casing and cap, when combined with its high speed and large data storage capacity, are sure to create an unprecedented speed experience for users. The 5Gbps ultrahigh speed brought by USB 3.0 technology, SSD performance, large capacity, shockproof, and quietness are all features of Team X101 USB 3.0 to ensure your complete satisfaction after your purchase
Features:
USB3.0 data transfer interface
Support hot swapping and plug n’ play
Backward compatibility with USB 2.0/USB 1.1
No external power source required (power adaptor)
Support power saving mode
Cap design
Aluminum casing
Product length: 70.7mm
Product width: 19.11mm
32Gb storage capacity
Read: Up to 180MB/s Max
Write: Up to 50MB/s Max
Only £9.98 inc VAT.
ORDER NOW
______
Arozzi Torretta Gaming Chair - Black @ £139.99 inc VAT
The Torretta chair brings style into gaming with sleek sewing lines, vibrant colors and quality fabric material.
With its ergonomic design along with adjustable armrests, adjustable height, 360 swivel rotation and tilt function makes the Torretta a very flexible gaming chair.
Light weight construction makes it easy to move the chair around without the sacrifice of quality.
It has 5 high strength nylon wheels to insure stability when having intense gaming moment.
- Thick padded seat and backrest.
- Ergonomic design.
- Fabric upholstery material.
- 360 Degree swivel rotation.
- Adjustable armrest, height adjustment and rotation.
- Adjustable height gas-spring.
- Tiltable seat with lock function*
- Lightweight construction for easy movement.
- Five twin wheel nylon casters.
- 4 different color choices.
* lock function works only in upright position.
Technical Details:-
- Total Height (with base): approx 120-128 cm
- Height (seat): about 45-53 cm
- Backrest Height: about 84 cm
- Overall Width: approx 52 cm
- Total depth: 53 cm
- Weight: about 22 kg
- Material: foam (padding), fabric (reference)
Only £139.99 inc VAT.
ORDER NOW
Dammm you Andy...
Getting a USB Drive now :)
Would love the chair too but.. USB it is for now.
More shiny things!!! :p
A quiet USB stick? Sold as mine are way too noisy, can hear the chips ticking as it writes the megabits. And if I'm copying music, sometimes it leaks out.
damn would have had one but only just got back form work and all gone. :(
Would love that chair but just a bit to expensive for my taste. would want to 'road test' it before dropping that much money on a chair.
