Seasonic Eco Series 430W '80 Plus Bronze' Power Supply @ £34.99 inc VAT
Seasonic announce the ECO-430, a 430W 80+ Bronze unit for the European market. Sporting S2FC technology, this unit provides Seasonic quality at a competitive pricepoint. The ECO-430 also has dual 12V rails, a 120mm FDB Fan, Double Forward Convertor design and a 3 year warranty.
Features
- Super High Efficiency [> 85%] 80+ Bronze 230V EU
- Smart & Silent Fan Control [S2FC]
- Ample +12V Power Output
- 120mm Fluid Dynamic Bearing (FDB) Fans
- Active Power Factor Correction up to 98%
- Double Forward Converter Design
- Ultra Ventilation [Honeycomb Structure]
- All-in-One DC Cabling Design
- Easy Swap Connectors
- Highly Reliable Electrolytic Capacitors
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 1 x 6+2-Pin-PCIe
- 3 x SATA
- 2 x 4-Pin-Molex
- 1 x FDD
- Warranty: 3yr
Only £34.99 inc VAT.
ORDER NOW
______
Saitek X52 Pro Flight Controller And Throttle Joystick - PC (PS34) @ £119.99 inc VAT
All the features of the X52 combined with premium engineering and advanced Multi-Function Display (MFD) for real flying interaction. The dual spring mechanism is effective giving you a more realistic feedback compared to the original X52. Precision centering mechanism, non-contact technology on X and Y axes and constant spring force reduce free play, improve control and increase durability.
- 2 dedicated MFD buttons and 2 rotary dials with in-built buttons to control additional game functionality
- MFD displays data directly from games, including Radio Stack info from Microsoft Flight Simulator
- Software Development Kit included for creating game-specific programs to interact with the MFD
- Choice of red, amber or green button illumination
- lluminated buttons and MFD - ideal for low light environments
- Throttle unit illumination varies depending on throttle position
- Enhanced MFD backlighting
- Improved cable management system
two-year limited manufacturer's warranty
Only £119.99 inc VAT.
ORDER NOW
Features
Connectors
- 1 x 6+2-Pin-PCIe
- 3 x SATA
- 2 x 4-Pin-Molex
- 1 x FDD
- Warranty: 3yr
ORDER NOW
______
ORDER NOW
