**TODAY ONLY! 20/01/2015** Asus Radeon R9 290X DirectCU II OC 4GB & LG Flatron 34UC87-P 34" WideScre
OcUK Staff
4 Feb 2013
Asus Radeon R9 290X DirectCU II OC 4096MB GDDR5 PCI-Express Graphics Card @ £281.99 inc VAT
The new card benefits from exclusive ASUS GPU Tweak, an easy-to-use tuning tool for instant performance boosts, 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions, and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and bring in-game audio to life with more accurate environmental sounds.
R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games and includes a free full game - the brilliant Battlefield 4™ from EA Digital Illusions Creative Entertainment™ (DICE).
The new ASUS R9 290X has a unique advantage in the shape of GPU Tweak, an exclusive ASUS tool that helps users to squeeze every last drop of performance out of the Radeon R9 290X GPU. This includes the ability to control finely GPU and video-memory clock speeds and voltages, cooling-fan speeds and power-consumption thresholds - so overclocking is both made easy and can be carried out with high confidence.
R9 290X is equipped with 4GB of high-speed GDDR5 memory, allowing gamers to push their favorite titles much further by upping in-game visuals to maximum resolutions. The new card also includes AMD Eyefinity technology to broaden the gaming landscape, so gamers can expand the playing field across up to six independent displays, via DisplayPort or DVI.
Specification:-
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1050MHz
- Memory Speed: 5400Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Only £281.99 inc VAT.
ORDER NOW
_____
LG Flatron 34UC87-P 34" WideScreen Super-Wide Curved LED Monitor @ £799.99 inc VAT
21:9 Curved UltraWide QHD (3440*1440) display offers visual comfort with 2.4 times more visual information at one time than a Full HD monitor. And also, the QHD resolution’s 1440p vertical height allows you to use more vertically than a 29 inch 21:9 monitor.
IPS’s 178’ wide viewing angles, close to 180’, allow you to view the screen clearly without distortion. Also, the Curved IPS provides an immersive viewing angle covering the entire viewing angle around your range of vision.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or print through a sRGB over 99% colourspace and IPS’s accurate colour expression.
34UC87 provides two Thunderbolt2 ™ ports to directly connect a Mac PC and Pegasus2 storage directly to transmit data more than four times faster, than a USB 3.0. As a result, there is no concern of slow transmission from using a USB or HDMI connection. You can connect to various devices with the two HDMI and two USB 3.0 ports, and a Display Port. And, If you have a Mac, you can connect directly to the 34UC87 via Thunderbolt 2™, which transmits data more than four times faster than USB 3.0.
Using MaxxAudio® technology you will experience deeper bass and crystal clear highs. Equipped with two 7w internal speakers and MaxxAudio® technology, the 34UC87 provides cinema surround- like sound, allowing you to enjoy movies without any extra external speaker or sound output equipment.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1
- Response Time: 5ms
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Curve: 3800R
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Speakers: 2x 7W
- Height adjust stand
- VESA: 100x100mm
- Set with stand: 830.5 x 224.5 x 472.9
- Set without stand: 830.5 x 106.4 x 370.3
- Weight: 8.2kg
- Warranty: 2yr (On-Site with LG - 0344 847 5454)
Only £799.99 inc VAT.
ORDER NOW
Again? It was on TO only a few days ago and you only sold one then.
LG need to make this 3 years warranty too.
