- 20 Jul 2009
- The bleak North East arm pit of Britain
Today we have a couple of awesome deals on a Zalmans new Z9 Plus Tower Case and an OCZ StealthXStream 2 600W Power supply.
Zalman Z9 Plus Tower Case with Fan Controller - Black @ £39.98 inc VAT
The latest offering from Zalman is the Z9 Plus which offers amazing value and great features. This chassis is a must for any new build. Regulating your interior temperature has never been so simple: as the Z9 Plus includes a built in fan controller and LED temperature sensor allowing you to fine tune your cooling. The Z9 comes equipped with a well designed side window to showcase all your components and allow further cooling with its semi-mesh design.
- Motherboard tray cut out for easy CPU backplate removal
- Dimensions: 207 x 464 x 504mm (W x H x D)
- 3 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- 1 x 2.5" Drive Bay
- Expansion Slots: 7
- Space for 290mm Graphics Cards
- Front I/O Ports: USB2.0 x 4 / 2 x Audio / Fan Controller / Temperature display
- Front Cooling: 120mm /140mm fan x 1 (120mm Blue LED fan x 1 standard)
- Top Cooling: 120mm /140mm fan x 2 (120mm Blue LED fan x 1 standard)
- Bottom Cooling: 120mm /140mm fan x 1 (optional)
- Rear Cooling: 120mm fan x 1 (included)
- Side Cooling: 120mm fan x 2 (120mm Blue LED fan x 1 included)
Was £44.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
OCZ StealthXStream 2 600W Power Supply @ £46.98 inc VAT
The new StealthXstream II strikes the right balance between mainstream power needs and high-performance build quality to deliver unprecedented value. Designed for both gamers and mainstream power users in mind, key features of the sleek StealthXstream II include a thermally controlled 120mm double-ball bearing fan maximum airflow at near-silent audible noise levels, exceptionally well regulated electrical noise and ripple for stable operation, an ideal array of connector types for each wattage, and excellent efficiency, converting up to a full 82% of AC to DC power at typical loads. The StealthXstream II Series from OCZ is fully compliant with the latest ATX12V and EPS12V specifications.
- Series: StealthXstream II
- Type: ATX12V V2.2 / EPS12V
- Wattage: 600W
- Fan Size: 120mm double ball-bearing
- PFC: Active
- Main Connector: 20+4-Pin, +12V Rails: 4, PCI-E Connector: 1 x 6-Pin +, 1 x (6+2-Pin) PCI-E, SATA Power 4
- Efficiency: Typical load 82% Efficiency
- Energy Certifications: 80 PLUS Certified
- Input Voltage: 100 – 240V
- Input Frequency Range: 50/60 Hz
- Output: +3.3V@25A,+5V@25A,+12V1@18A, +12V2@18A, ,+12V3@18A, +12V4@18A
- [email protected],+5VSB @ 3.0A
- Dimensions: 15cm x 8.5cm x 14cm (W x H x L)
- Connectors: 1 x Main connector (20+4Pin), 1 x 8 (4+4) Pin, 1 x 6-Pin PCI-E, 1 x 6+2-Pin PCI-E, 6 x Peripheral, 4 x SATA, 1 x Floppy
- 3 Year Warranty
Was £50.99 Inc. VAT
Only £46.98 inc VAT.
ORDER NOW
Was £44.99 Inc. VAT
ORDER NOW
- Wattage: 600W
- PFC: Active
- 3 Year Warranty
Was £50.99 Inc. VAT
ORDER NOW
