**TODAY ONLY! 23/02/2015** OcUK Monolith Full Tower Case & Kingston MobileLite Wireless Reader
OcUK Staff
4 Feb 2013
OcUK Monolith Full Tower Case - Black @ £64.99 inc VAT
Big and brash! The OcUK Monolith Case offers the best of the best for any extreme PC build. Supporting room for two Power Supplies and room for an SR2 system and a full water cooling accompaniment.
- SATA dock to install 3.5 inch and 2.5 inch Hard Drives easily
- CPU cooler window on case board: to install CPU cooler without removing motherboard
- All HDD trays support 2.5 inch Hard Drives (10 internal Hard Drive Tray)
- Ready to use super speed USB 3.0
- Supports 4Way graphic cards
- Supports water cooling
- Advanced cable management routes
- Screw-less design for 5.25 inch devices
- Drive Bays: External 5.25" Drive Bays: x 4
- Internal 3.5" Drive Bays: x 10
- Front I/O Access USB 3.0 x 2 / USB 2.0 x 2 / Audio x 1 / Mic x 1
- Expansion Slots: 10 Slots
- Mainboard: HPTX, XL-ATX, EATX, ATX, Micro-ATX
- Front Cooling: 1 x 140mm front fan
- Rear Cooling: 1 x 140mm rear fan
- Fan Delay Board: x 2
- Water Cooling Support : x7
- Dimensions: 619mm (D) x 229mm(W) x 567mm (H)
Only £64.99 inc VAT.
ORDER NOW
______
Kingston MobileLite Wireless reader - MLW221 @ £14.99 inc VAT
Kingston’s MobileLite Wireless reader delivers an unparalleled mobile experience. Because it’s not just about being connected, it’s about having unlimited access to your favourite videos, music, photos and files from your Flash drive and other storage devices — anywhere you go. Store and share more — wirelessly and easily via Wi-Fi — and stream content (for example, three different movies) to three devices at once. Plus, MobileLite Wireless features a battery charger that lets you charge your mobile device to keep you productive. It’s backed by a one-year warranty, free technical support and legendary Kingston® reliability.
- Use your existing USB and SD cards
- Share data with three users simultaneously
- Battery backup for your USB-enabled mobile devices
- Inputs for storage USB and SD — reads SD, SDHC, SDXC and microSD (with included adapter)
- File Format: FAT, FAT32, NTFS, exFAT
- Dimensions: 124.8mm x 59.9mm x 16.65mm
- Weight: 98g
- Wireless network interface: Wi-Fi 802.11g/n with wireless security (WPA2)
- Rechargeable battery: up to 5 hours of continuous use
- Battery: built-in Li-Polymer 1800 mAh 3.7v
- Local storage 1 wirelessly transfer files to and from the MobileLite Wireless app and the MobileLite Wireless hardware
- Camera Roll support 1 allows users to move photos from their mobile device to MobileLite Wireless in order to free up space
- Cable: USB to micro USB cable included
- Operating temperature: 0°C to 40°C
- Storage temperature: -10°C to 45°C
Only £14.99 inc VAT.
ORDER NOW
