**Today Only 25/02/2011** Coolermaster Silent Pro Gold 600W PSU & Corsair XMS3 6GB 1600MHz DDR3
22 Aug 2010
Today Only, we have 40 units of Corsair XMS3 6GB 1600MHz DDR3 Memory for only £47.99 inc. VAT. This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed.
We also have 15 units of Coolermaster Silent Pro Gold 600W Power Supply for just £70.66 inc. VAT. The Silent Pro Gold series features an entirely new design with several innovative and patented technologies. Cooler Master has created HTT™ (Heat Transfer Technology), a unique “L-shaped” heat-sink designed to vastly improve the airflow inside the power supply, resulting in lower operating temperatures.
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (CMX6GX3M3A1600C9) @ £47.99 inc VAT
The XMS Series CMX6GX3M3A1600C9 is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s high performance heat sink which includes Intel’s Extreme Memory Profiles (XMP 1.2). This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 9-9-9-24 at 1.65V VDIMM.
- Each three module set is tested at 1600MHz
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.65V, at latency settings of 9-9-9-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.65V
- 6144 Megabytes of DDR3 memory
- Three matched 2GB modules
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Only £47.99 inc VAT.
ORDER NOW
Coolermaster Silent Pro Gold 600W Power Supply @ £70.66 inc VAT
The Silent Pro Gold series features an entirely new design with several innovative and patented technologies. Cooler Master has created HTT™ (Heat Transfer Technology), a unique “L-shaped” heat-sink designed to vastly improve the airflow inside the power supply, resulting in lower operating temperatures. Another unique feature to the Silent Pro Gold series is the Hybrid Transformer™ which mounts the transformer directly to the heatsink. This makes for a more compact transformer and improves the power efficiency at the same time.
Yet another feature that helps improve the power efficiency is Hyper Path™ which is a “hyper link” between the transformer and the various power conversion components. The “hyper link” results in almost a loss-less transfer of energy which has never been done before. Combine all three of these features and you got one of the most quiet and power efficient power supplies in its category. The entire range offers a power efficiency that exceeds 90 percent at 220V, starting from a load of about 50 percent (model dependant), with some models never dropping below 90 percent. During normal use (up to about 50 percent load), neither model exceeds 21 dBA of fan noise thanks to the low RPM fan design combined with the new heat-sink design.
- 90% efficiency typically
- 80 Plus Gold Certified
- 3-way SLI or CrossFireX Support
- A unique "L-shaped" heatsink to remove heat from the PSU
- Hybrid Transformer: Unique design that combines heat-sink with transformer
- Flat modularised cables provide easy cable management leads to better airflow
- Compliance with the latest ATX V2.3 standard
- Operation with intelligent fan speed control
- High reliability (MTBF > 100,000 hours)
- Double Layer EMI filter retains noise and to avoid affect to users
- Integrating active PFC with PWN combo controller while increase efficiency
- Multiple protection design (OVP/UVP/OPP/OTP/SCP/OCP)
- Japanese made capacitors
- Single +12V rail up to 98A
- Five year warranty
Only £70.66 inc VAT.
ORDER NOW
That price on the 6GB XMS3 kit we've done is truly shocking, in a very positive way of course. :D
