**Today Only 26/03/2011** XFX ATI Radeon 6950 2048MB Graphics Card & Corsair XMS3 4GB 1600MHz DDR3 M
22 Aug 2010
Today Only, we have 50 units of the powerful XFX ATI Radeon 6950 2048MB Graphics Card for only £189.98 inc. VAT. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Enjoy a gaming experience like no other.
We also have 50 units of Corsair XMS3 4GB 1600MHz DDR3 Memory for only £35.99 inc. VAT. This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24.
XFX ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card @ £189.98 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- ATI Reference Design (Revision: 1) - Flashable too 6970
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 2 Years
Only £189.98 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £35.99 inc VAT
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
- Sandybridge compatible (use sub 1.60v)
Only £35.99 inc VAT.
ORDER NOW
Check on anandtech bench to see the difference.
The 6950 is quicker but if you running something like a 1080p /22 inch monitor or less
do you need the extra speed ? The 5850 isnt what you call slow ! For a little bit more
than 1 6950 you could pre order 2 5850's ...
