Zalman ZM 1250W '80 Plus Platinum' Modular Power Supply @ £119.99 inc VAT
Thanks to a new design the ZM1250 efficiency of the unit is very high 89-93% (20-100% load) top efficiency. It also uses a powerful and highly reliable DC-DC module (to increase performance and reliability), along with full bridge and LLC resonant circuits which lowers switching losses, boosts efficiency and is guaranteed to deliver 1250w continuous power even in a warm case (up to 50 °C).
The ZM12050-Platinum boasts an ultra-quiet 140 mm fan, the speed of which is controlled by the Smart Fan Control system. This means that the fan won't spin at all until the PSU is under 40% load and this minimises audible noise ensuring the PSU remains as quiet as possible during operation.
Component quality is always vital for the longevity of a PSU and Zalman are now using high quality Japanese capacitors. These offer greater stability at higher operating temperatures, frequencies and currents giving a high powered PSU like the ZM12050-Platinum the edge in reliability and performance.
It also incorporates heavy-duty protection circuitry which guards against over-current, over-power, over-voltage, over-temperature, under-voltage and short circuits.
As with most modern PSU designs, this unit features a modular cable system. This allows you to remove those cables which aren't needed, improving the appearance, maintainability and airflow inside your PC case. A further benefit is that all the cables themselves are flat which makes them less bulky and cable management even easier.
Eight PCI-E cables allow this PSU to support 4-way SLI and CrossFireX configurations making this the perfect PSU for high-end gaming enthusiasts.
- 80 PLUS Platinum certified PSU 89-93%
- Smart Fan control system - Fanless up to 40% load
- Guaranteed to provide 1250W continuous power
- High quality 105°C Japanese capacitors
- Multi-GPU ready for 4-Way CrossFireX and SLI
- Full Bridge and LLC resonance circuit with DC-DC module
- Smart fan control system
- Meets ErP 2010 Lot6 standby power standards
- Safety / EMI Approvals, CE, FCC, UL, CB, KC certified
- 5 Year warranty
Only £119.99 inc VAT.
ORDER NOW
_____
Corsair 2100 Wireless Dolby 7.1 Gaming Headset (CA-9011125-EU) @ £70.99 inc VAT
The Corsair Vengeance 2100 delivers high performance gaming audio without the wires. The powerful 2.4GHz connection gives you up to 40 feet of wireless range and up to 10 hours of battery life. Accurate Dolby 7.1 multichannel audio helps you pinpoint your enemies’ location before they see you. Large 50mm drivers offer better bass response and crisp, clear midrange sound and the noise cancelling microphone lets you be heard loud and clear. The closed-back, circumaural earcups reduce environmental noise for a more immersive gaming experience. Plus the earcups feature microfiber-covered memory foam earpads for hours of comfortable gameplay.
Features:-
- 2.4GHz wireless audio - High performance gaming audio without worrying about wires.
- Dolby 7.1 surround - Accurate multi-channel audio helps you locate opponents even if you can¡¦t see them.
- Large 50mm drivers - Better bass response and crisp, clear midrange for more audio quality and a competitive edge.
- Designed for comfort - Microfiber-covered memory foam earpads and a padded headband let you play longe
- Noise cancelling microphone - Be heard loud and clear, whether you¡¦re playing or just chatting between matches.
- Large diameter, circumaural earcups - Blocks distracting sounds and keeps your head in the game.
Specification:-
Headphones
- Frequency Response: 20Hz - 20 kHz
- Impedance: 32k Ohms @ 1 kHz
- Drivers: 50mm
Microphone
- Type: Unidirectional noise cancelling
- Impedance: 2.2k Ohms
- Frequency Response: 100Hz ¡V 10kHz
- Sensitivity: -37 dB (¡Ó 3 dB)
Wireless
- Range: Up to 40 feet (12m)
- Battery life: Up to 10 hours
Only £70.99 inc VAT.
ORDER NOW
- 5 Year warranty
ORDER NOW
_____
Features:-
Specification:-
Headphones
- Drivers: 50mm
Microphone
Wireless
ORDER NOW
