**TODAY ONLY! 27/03/2015** Lian LI PC-O5X Mini ITX & Creative Sound Blaster Zx High Performance Soun
OcUK Staff
4 Feb 2013
Lian Li PC-O5X Mini-ITX Chassis - Black @ £214.99 inc VAT
Lian-Li Industrial Co. Ltd, has launched the O Series open-air, wall-mountable chassis: PC-O5X, PC-O5SX, PC-O6SX and PC-O7SX. Previewed to the worldwide technology community in its prototype stage, the O Series chassis final design reflect the feedback of the DIY community, and feature oversized tempered glass windows, a PCI riser cards, and sleek aluminum construction.
Four Open-Air, Wall-Mountable Aluminum Chassis
The new O series includes four chassis: the mini-ITX PC-O5, the mini-ITX PC-O5S, the micro-ATX PC-O6S, and the ATX PC-O7S. These aluminum constructed cases all feature a similar design and aesthetic differing in their hardware compatibility.
Show Off Your Hardware in Slim Profile Chassis
Through the oversized tempered glass window, onlookers can see the entire build unrestricted. Graphics cards are installed parallel to the motherboard, keeping the chassis slim, thanks to the included PCI riser card and extension. A black anodized aluminum shield covers the hard drive cage to keep a super clean look.
Customizable Storage Options
The O Series chassis give builders several options for storage installation. Hard drives can be mounted in the hard drive cage, hidden by an anodized aluminum shield, directly mounted on the motherboard tray, or installed on a removable bracket behind the motherboard.
Water Cooling Support
The PC-O5S, PC-O6S, and PC-O7S support AIO water cooling systems. The “S” suffix in the aforementioned models denotes water cooling compatibility. The PC-O5S supports radiators up to 240mm, while the PC-O6S and PC-O7S supports 360mm radiators.
Versatile Placement
The O Series cases can be mounted to the wall, placed on a desk in the vertical position using the included aluminum stand with rubber grip, or arranged horizontally on four attachable feet with rubber padding.
Features
- Rear 140mm system fan
- Black Interior
- HDD rack can support two 3.5" drives and one 2.5" drive.
- Supports SFX PSU
- Support for 2 x 2.5" drives on the MB tray or 1 x 3.5" & 1 x 2.5" (Occupies PCI slot space)
- Support for 2 x 2.5" or 1 x 3.5"/2.5" on the rear of the MB tray
- Supports 190mm VGA, 70mm Cooler, 140mm PSU
- 5mm Tempered glass side panel
- 2 x USB3.0 ports
- Slim ODD rack
- Dual VGA card support
Specifications
- Model: PC-O5X
- Case Type: Mini Chassis
- Dimensions: (W)384mm, (H)390mm, (D)133mm
- Colour: Black
- Side Panel: Tempered Glass
- Body Material: Aluminum
- Net Weight: 5.4kg
- 5.25" Drive Bay: 1 (Slim ODD) or 3.5"/2.5" HDD x1
- Drive Bays: HDD Rack: 3.5" x2 + 2.5" x1, Behind the MB tray: 3.5" x1 + 2.5" x1 or 2.5" x2, On the MB tray: 3.5" x1 + 2.5" x1 or 2.5" x2 (Occupies PCI slot space)
- Expansion Slot: 3, PCI-E 16X Riser Cable: 1 (Gen 3.0)
- M/B Type: mini-ITX
- System Fan: 140mm fan x1
- I/O Ports: USB3.0 x 2, HD Audio
- Maximum Compatibility: VGA length: 190mm (175mm when using a VGA card with a front-located power plug), PSU length: 140mm, Cooler height: 70mm
- PSU Type: SFX PSU
Only £214.99 inc VAT.
ORDER NOW
______
Creative Sound Blaster Zx High Performance Gaming Sound Card - Retail (70SB150600001) @ £79.99 inc VAT
116dB Signal-To-Noise Ratio
A signal to noise ratio or SNR of 116dB means your audio will be > 99.99% pure audio which is 34.4 times better than motherboard audio.
SBX Pro Studio™ technologies
Experience awe-inspiring audio with the SBX Pro Studio suite of technologies that immerses you in your games and movies with amazing detail and a 360-degree true-to-life sound stage.
Crystal clear communication
In gaming, if you're not communicating, you're not winning. Experience crystal clear commmunication with your teammates with the CrystalVoice™ suite of technologies that removes echoes, ambient noises and picks up your voice from within a zone (CrystalVoice Focus). It also maintains your voice level even if you move near or further away from the microphone.
Advanced home entertainment audio
Experience like never before the power of Sound Blaster audio with your home entertainment today! With Sound Blaster Zx's gold-plated connectors, speaker optimization technology and digital content encoding capability, you can be assured of only the best digital audio possible.
Accessible Audio Control Module (ACM)
Take control in style and ease with the ACM that incorporates a built-in microphone array and mic/headphone I/O connections. The knob on the ACM lets you conveniently adjust the headphone levels.
Sound Core3D audio processor
The quad-core Sound Core3D™ audio processor was designed to offload SBX Pro Studio and CrystalVoice effects processing from your primary CPU, improving your overall PC performance, resulting in drastically superior audio and voice quality.
Experience like never before the power of Sound Blaster audio with your home entertainment today! With Sound Blaster Z's gold-plated connectors, speaker optimization technology and digital content encoding capability, you can be assured of only the best digital audio possible.
High fidelity surround sound
Connect to your home theatre system through a single digital cable and enjoy cinematic DVD movies by transforming any stereo or multi-channel streams into high fidelity immersive surround sound.
Never unplug your headphones again
With the Sound Blaster Z-series Control Panel, just toggle between your headphone and speaker system with a flip of a switch.
- Output Level (Full Scale): Front Channel Out : 2Vrms, Headphone (33 ohms): 1.3Vrms, Headphone (600 ohms): 2Vrms;
- Maximum DAC Resolution: Front Channel Out : 24-bit, 192kHz, Headphone (33 ohms): 24-bit, 96kHz, Headphone (600 ohms): 24-bit,
96kHz;
- SNR (20kHz Low-pass filter, A-Wgt), @ 24-bit, 96kHz: Front Channel Out : 116dB, Headphone (33 ohms): >105dB, Headphone (600
ohms): >105dB;
- Frequency Response @ 96kHz: Front Channel Out : 10Hz to 45kHz, Rear Channel Out : 15Hz to 45kHz, Center Out : 10Hz to 45kHz,
Headphone (33 ohms): 10Hz to 45kHz;
- Frequency Response @ 192kHz(Stereo only): Front Channel Out : 10Hz to 88kHz;
- Supported Output: Stereo/2.1 Speakers, 5.1 Speakers, Headphones;
- Headphone: 1 x Amplified 1/8" mini jack;
- Speaker Out: 3 x 1/8" mini jacks;
- Optical Out: TOSLINK;
- Optical In: TOSLINK;
- Line In / Microphone In: Shared 1/8" mini jack;
- Warranty: 2 Years Manufacturers Warranty;
Only £79.99 inc VAT.
ORDER NOW
