**Today Only 27/04/2011** Hitachi Deskstar 5K3000 2TB SATA 6Gb/s 32MB & Coolermaster Elite 342 Case
22 Mar 2011
Cheshire
Take a look at today's fantastic Today Only offers!
Coolermaster Elite 342 Case - Black @ £22.98 inc VAT
Elite 342 (RC-342) is a mini-tower that accommodates micro-ATX, built with a modern black design body and front panel. This chassis maintains Elite’s pedigree of compact-sized and quality build that would look great in any space. Elite 342 maintains a quiet environment while providing the option of adding 80mm or 90mm rear fans to provide the best ventilation possible for a compact system.
- Front mesh design provides superior ventilation to maintain constant cooling
- Front I/O panel provides easy access for users
- Side panel security lock hole for higher security
- Side ventilation holes for better cooling performance
- Front 120 mm fan provides the best cooling solution
- Removable HDD cage
- Dimensions: 180 x 352 x 440mm
- Motherboard Compatible: Micro ATX
- 2 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- I/O Ports: USB2.0 x2 / Audio x 2
- Front Cooling: 120 x 25mm fan x 1 / 1200 RPM / 17 dBA
- Rear Cooling: 80 / 90 mm fan x 1 (optional)
- Expansion Slots: 4
- 2 Year warranty
Was £27.98 Inc. VAT
Only £22.98 inc VAT.
ORDER NOW
Hitachi Deskstar 5K3000 2TB SATA 6Gb/s 32MB Cache 5900RPM - OEM @ £54.98 inc VAT
The Deskstar™ 5K3000 is Hitachi’s first hard drive to deliver an enormous two terabytes of storage capacity and 5900 RPM performance in a standard 3.5-inch form factor. The 5K3000 is also one of the first Hitachi hard drives with a 6Gb/s SATA interface, which along with its 32MB cache buffer delivers a big boost to performance over the previous generation product.
- Backwards compatible with SATA-II
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA 6Gb/s
- Spin Speed: 5900RPM
- Warranty: 3 Years
Was £61.99 Inc. VAT
Only £54.98 inc VAT.
ORDER NOW
Hey,
Nice price on the 2tb drives, but
The Elite 342 is one of the best entry level mATX cases, at only £22.99 inc VAT is epic.
The english is terrible under the case. Even if it had "it is epic" it wouldn't really fit with what the case is.
