Today only, capture your fantastic memories or even make a picture blog installing your Sapphire ATI Radeon HD 5850 into your new system with the BenQ C1230 12MP Compact Digital Camera - also perfect for summer. Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors.
Sapphire ATI Radeon HD 5850 Extreme 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** @ £119.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 725MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 128.0GB/s
- Processing Cores: 1440
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- 2yr Warranty
Only £119.99 inc VAT.
ORDER NOW
BenQ C1230 12MP Compact Digital Camera - Silver/Pink @ £29.99 inc VAT
The BenQ C1230 is ideal for anyone who just wants a simple point and click compact digital camera that is easy to use and takes good quality photos. Its ideal for children, students and even those looking to get into photography. Robust and small enough to take everywhere with you, so you never miss the opportunity to take a photo and at a cost where if the kids do break it or drop it then its not cost the earth, making this camera an ideal gift for Birthdays, Christmas, Valentines Day etc.
With smart scene mode automatically detects 8 different types of scenes and chooses an appropriate one out of the following 8 scene modes: Landscape, Portrait, Backlight, Backlight Portrait, Night Scene, Night Portrait, Macro, and Sunset. All you have to do is press the shutter and the Auto Scene Mode will do the rest for you.
With 5cm Macro, it will automatically scan and switch to the Macro mode when you are taking close-up photos of flowers or small objects. So every photo is in focus.
Want to take a good photo when there are just two of you? Love Portrait mode will take a shot when detecting at least two faces.
Blink Detector alerts you when a subject has blinked, allowing the shot to be retaken immediately or saved according to your preference.
Specification:-
- Sensor SONY 12 Mega Pixels, 1 / 2.3 inch CCD
- Picture Resolution 12M / 3:2 / 8M / 5M/ 3M / HD 16:9 / VGA
- Lens f = 6.2 ( W ) ~ 18.6 ( T ) mm
- F= 3.0 (W) ~ 5.6 (T) (f = 34.6~103.8mm, 35mm equivalent)
- Zoom Optical: 3X
- Digital: Up to 5X (Preview) / Up to 12X (Playback)
- Focus Range Normal: W=80cm ~ Infinity
- Macro: W=5cm ~ 100cm
- Shutter Speed 1/2000 ~ 1 sec. (Fireworks 2 sec.; Manual 15 sec.; Night Scene 8 sec.)
- Display Size 2.7" LCD
- Display Resolution 230,000 pixels
- ISO Equivalent Auto / 50 / 100 / 200 / 400 / 800 / 1600 / 3200 (3M or lower) / 6400 (VGA and HD 16:9 only)
- White Balance Manual (6 modes in manual selection : Daylight / Cloudy / Tungsten / Fluorescent H / Fluorescent L / Manual)
- Flash Auto Flash, Auto Anti Red-eye, Force On, Slow Sync, Forced Off
- Self-Timer 2 sec. / 10 sec. / Double / Burst
- Movie Mode 720 x 400 (16:9) / 640 x 480 / 320 x 240 / Web sharing
- 30 fps, Continuous recording with sound
- Storage Built-in Approx. 21.1MB
- 4GB SD compatible / 32GB SDHC card compatible
- Interface Digital output: USB 2.0 compatible
- Audio / Video output (NTSC/PAL)
- PictBridge compatible
- Battery AA Battery x 2
- CIPA Approx 200 base on bundled batteries
- Dimensions (W x H x D) 92.0 x 60.5 x 23.8 mm
- Weight 120 g (without battery & SD card)
- Accessories (Standard) USB Cable / Software & UM CD / Quick Guide / Hand Strap / Pouch /AA Battery x 2
- Product Color: Silver / Pink
- 2yr Warranty
Only £29.99 inc VAT.
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- 2yr Warranty
ORDER NOW
Specification:-
- Zoom Optical: 3X
- 2yr Warranty
ORDER NOW
