TODAY ONLY 2ND APRIL 2011 - ASUS GTX 480 & CORSAIR A50 COOLER
11 Dec 2005
Cheshire
Today Only we have 30 units of the fantastic Asus GTX 480 Graphics card for only £191.99 inc VAT. Featuring cinematic DX11 graphics the 480 is the GFX card of choice for real hardcore gamers.
We also have 60 units of the Corsair A50 CPU Cooler for only £23.99 inc VAT. Compatible with every socket on the market and boasting fantastic cooling properties, the A50 allows for the highest of overclocks.
Asus GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card with Far Cry 2 @ £191.99 inc VAT
Next generation gaming has arrived. Nvidia GeForce GTX 480 gives your games an adrenaline shot with the world's fastest performance and futuristic, visually stunning graphics. Experience heartpounding, cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jawdropping stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 480: pure adrenaline meets visual bliss.
- Voltage Tweak Technology
- Core Clock: 700MHz
- Memory: 1536MB GDDR5
- Memory Clock: 3696MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 480
- Shader Clock: 1401MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
- Supplied with Starcraft II Trial & Far Cry 2 PC Games
Only £191.99 inc VAT.
ORDER NOW
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £23.99 inc VAT
Excessive heat is the deadly enemy of high-performance silicon, and the Air Series A50 CPU cooler can extend the lifetime of your CPU by quietly and efficiently drawing that heat away. You’ll get faster performance, too. Intel Core™ i5 and Core™ i7 processors can be easily configured to automatically overclock when conditions are right. Lowering your CPU’s operating temperature one of the best ways to do this – your CPU will detect that it’s running cooler, and instantly boost its speed when you need it. Of course, if you’re not using a Core i5 or Core i7 or if you prefer to adjust your overclocking settings manually, the Air Series A50 will give you the temperature headroom you need.
The superior engineering of the Air Series A50 makes it dramatically outperform your CPU’s stock heatsink: three 8mm copper heatpipes directly contact your CPU and instantly pull heat up into the aluminum cooling fins. A 120mm fan, mounted on rubber studs to reduce noise and vibration, quietly draws cool air through the fins.
Spend 15 minutes replacing your CPU’s stock heatsink and enjoy years of better performance.
- Compatible with Intel and AMD systems
- Three 8mm copper direct-contact heatpipes
- Aluminum fins
- Low-noise, low-vibration 120mm fan mounted on rubber studs
- Selectable 1,600 or 2,000RPM fan allows you to select the cooling performance you want
- Air flow: 50 - 61 CFM
- Noise level: 26 - 31.5 dBA
- Two-year warranty
Only £23.99 inc VAT.
ORDER NOW
That cpu cooler is very good, its better than the Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler, I currently have the A50 but I will be moving to liquid cooling soon. Maybe the H50 or the H70.
