**TODAY ONLY! 30/01/2015** LG Flatron 29UB55-P 29" WideScreen Super-Wide Monitor & Kingston HyperX S
OcUK Staff
4 Feb 2013
LG Flatron 29UB55-P 29" WideScreen Super-Wide LED Monitor @ £239.99 inc VAT
The 21:9 ratio is the perfect professional fit for software engineers, video / sound editors, and graphic designers. Imagine 2 conventional high quality monitors attached for multi-tasking, but their screens connect and extend seamlessly. Now you can use a program with long-range panoramic view in full length, without any bezel in the middle or dragging cursors. No longer divide your focus into separate monitors, the 29UB55 is the perfect companion for your profession.
Like other smart devices, the 29UB55's Pivot & Height Adjustable feature allows you to simply rotate the screen to fit vertically long images or files. When pivoting, you can easily adjust its height too. Leave dragging and scrolling behind. Let the monitor adjust to your images and needs.
Connect two devices to a single monitor with Dual Link-up that allows an HDMI + HDMI link. Now you and your colleague can simply bring each other's devices and connect to a single monitor to share and compare information. Freely show and control your screen while watching your partner doing the same on the opposite side of the monitor. Don't bother installing annoying projectors in your small room or worry when your conference room is occupied, the 29UB55 is here for you.
With its wide screen ratio, now you can open 4 programs on a single screen to see your information in a single glance while working. The size of sub screens is user-controlled. The 29UB65 is compatible with Mac® and not only provides convenience but also productivity in a single click, you can split your screen into 2 to 4 subscreens.
Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for as long as you would like to.
As LG IPS Monitor features consistency and less changes in colour temperature, it offers a colour impression identical to that of the original image. You can enjoy lifelike picture picture quality without any colour shift whether you are standing or lying down. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort.
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
The joystick is a harmony of accurate menu controls and analogue sensitivity. With the fun control of a conventional joystick, its modern technology and design allow for simple control with a pleasant touch. In addition, intuitive UI with no overlapping is easier to understand and select menus.
Specification:-
- Screen size (inches): 29"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 2560*1080
- Brightness (cd/m2): 250
- Contrast Ratio: 50000000:1
- Viewing Angle (°): 178/178
- Colour Depth (Num of Colours): 16.7M (6-Bit +FRC)
- Colour Gamut: sRGB 100%
- Surface Treatment: Hard Coating (3H), Anti-Glare
- Connectivity: 1x DVI-D, 2x HDMI, 1x DisplayPort
- Speakers: 2x 5W
- Height adjust stand
- Warranty: 2yr (On-Site with LG - 0344 847 5454)
Only £239.99 inc VAT.
ORDER NOW
______
Kingston HyperX Savage Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/16) @ £129.95 inc VAT
Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. HyperX Savage is XMP Ready and comes in a range of speeds from 1600MHz to 2400MHz. Its trend-setting design puts you and your system ahead of the game.
Features:-
- Fast - top-performing modules available with low-profile heat spreader
- Unique - red, asymmetrical heat spreader sets new trends for PC builds
- Quality - aluminium die-cast heat spreader with a diamond cut finish
- Design - low profile to fit under oversized CPU coolers
- Reliable - 100-percent factory tested
- Guaranteed - lifetime warranty, free technical support
Specification:-
- Capacity 4GB-8GB (single), 8GB-32GB (kits)
- Frequency Speed 1600MHz, 1866MHz, 2133MHz and 2400MHz
- CAS Latency CL9-CL11
- Voltage 1.5V, 1.65V
- Operating Temperature 0°C to 85°C
- Storage Temperature -55°C to 100°C
- Dimensions 133.35mm x 32.8mm
- Compatible with H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
- Warranty: Lifetime
Only £129.95 inc VAT.
ORDER NOW
Has anyone here bought this monitor?
If so, how is it for gaming, ideally in racing simulators?
I have a 21:9, 29" Ultra wide monitor although not that exact model and I love it. I mainly play Battlefield 4 but the game supports it natively in game but there are issues with loading screens and post round screens but in game it's fine. I don't play many racing games these days so I would check the games you play support the resolution. Other than that I'm loving it and full screen movies rock!
There's a decent sized thread in the monitor section on the 29" variants too. http://forums.overclockers.co.uk/showthread.php?t=18614720
